![]() | Home > Puma (Tdci) > headlamp switch problem |
| johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371
anyone have one or have replaced one?
thanks for the advice--- John 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Here you go John,
May point you in the right direction.... http://www.defender2.net/forum/topic5649.html?highlight=burnt http://www.defender2.net/forum/topic11186.html?highlight=solder If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2114
me,
2 times: it is a easy work. Took 1 hour or less. Appear to be a common fault (at least in mine). Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Told it's a common fault, mine went after 2 years, just wouldn't turn on. Seemed locked solid.
Merlin |
| mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645
Common fault across all Defenders - switch often burns out.
I agree - making a realy kit is simple and we have all the parts in stock. However it is the spec of the kit that makes it complicated. A few examples would be Tinned cable to resist corrosion? Waterpoof relay holders and bases? All these add cost then we tend to get blasted by people who can pick the parts up from Ebay for 15 Tim |
Of course LED headlights draw half the power so are much less likely to cause switch failures
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
and having seen the new sidelight models, they look fantastic too ... |
They all look fantastic and the light they throw is too. I am only too well aware of the vulnerability of glass.... Treat every day as if it is your last....one day you will be right!! |
Glass is the better material
| Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 887
Mine burnt out (on a TD5), coupla minutes wiv a Pozidriv screwdriver, job done. BUT, on my LHD Puma it looks as though some of the fixings on the underside of the steering wheel cowling are made inaccessible by the mini shelf underneath it. I havent looked too closely, but when this switch burns out (note I didnt say if), is it necessary to remove this mini shelf to split the cowling - I couldnt see at first glance where it was fixed - and how fiddly is it? Peter |
Peter - do you have the same heat from the left and right sides of your heater ? I have LHD model too and there is a small difference .. did you have yours fixed ? |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
I made a loom for my 110 after the lights died on Salisbury plain one night.
I just used 2 relays, a plug from an old switch and a socket (for the same) that I had on an old dash loom. It's prely plug & play, as the relays get their voltage from the main headlight feed anyway. the switch just turns the relays on (one for sidelights, one for main beam) and the relays do the switching. With a bit of cable, about 6", there's enough slack to fit the relays behind the dash. |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Anyone got a part number for the light switch? Lucas or LR. Is it the plug in or the flat spade type connecor?Might get a spare. Went on the tdi a few years back, interesting journey home using the hazard warning lights! 1982 88" 2.25 diesel
