Home > Puma (Tdci) > Engine rear heatshield loose |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10361 |
Its attached to the cat/exhaust downpipe from the turbo, its not easy to get to from underneath, but it is easier...
A cat replacemant downpipe (avoid Terrafirma ) from a good supplier, (I put a Twisted one on a Puma), comes with a bracket to attach the heat shield, then all rattles can be solved. If the shield has 'torn' from where it's bolted on, a larger penny washer usually suffices if you don't want to replace the cat. |
25th Jun 2012 7:06pm |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 |
Thanks, I'll go and have a look from underneath
25th Jun 2012 7:37pm |
