Home > Puma (Tdci) > Fitting "soft" A Bar
lornick
Scotland 1988 Defender 90 300 Tdi HT Epsom Green
Hi Guys,
I was wodering if anyone has any fitting instructions for a genuine Defender A Bar? I've just got hold of one, but it came without any fittings - I'm looking for the correct size of bolts require to attach it to the bumper.
Also interested in attaching spotlights and was wondering where I would source the brackets that run from under the bonnet to the top of the A Bar (without using the local stealer!).
Thanks
Post #15153 6th Sep 2009 9:18pm
landroverdiver
A Bar
Hi
Where are you in Scotlsnd?
I fitted genuine soft A bar to my 2007 truck, happy to let you see it, if this helps.
PM me if any use to you
Post #15157 6th Sep 2009 10:06pm
mse
Post #15161 6th Sep 2009 11:41pm
lornick
Thanks..........
Thanks for the link - makes life easier!
Landroverdiver - I'm about 20 miles west of Aberdeen, so thanks for the offer but I'll probably see if I can crack on using the links I now have.
If I get really stuck I'll maybe take you up on it.
Cheers,
Post #15171 7th Sep 2009 8:49am
chalky
The fitting kit for said Soft A Bar can be bought seperately !
Try duckworths i got mine from there, they posted it out and it was here the next day ! DEFENDER XS CSW 08 TONGA GREEN
Post #15178 7th Sep 2009 10:47am
Happyoldgit
I think I got mine (A bar with the bullbar side bits too) from Duckworths. Fitting is easy but took it off after a while as in the end I didn't really like the look of it.
Post #15231 8th Sep 2009 4:43pm
mse
Mine came from a dealer down south - although the winch version, it was a pig to fit..im not so sure something wasnt right (could be anything up to and including the car Rolling with laughter ) - but in the end its on Mike
Post #15237 8th Sep 2009 5:32pm
