![]() | Home > Technical > puma diff noise |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
Most likely to be the crown-pinion out of spec. Yours is a 2010?
![]() ............................................................. Earth first. Other planets later |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
yes oct 2010, is this a quick fix or will the dealer need it days?
It is a full day job for a well trained person. A couple of days if nothing is severely worn out. Puma 110" SW
its only done 4000 miles
Well. Dono what to say as it is a LR. Just take it to a capable dealer. Puma 110" SW
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 ![]() ![]() |
hi mine is good now after about 7 diff and alot of trouble thay got it right there is still a slight noise but i can live with that after all it is a defender and thay make noises cheers tim
Aaron Kendon Member Since: 19 Jun 2012 Location: Melbourne Posts: 5 ![]() ![]() ![]() |
Yep exact same model and year, my diff is definately noisy in overun. Mate have i had dramas with mine. 5 egr valves, a new engine, panels coming away from under passengers seat, front diff burnt oil, you name it mine has done it. Not happy any more with it, my first brand new car ... did have a 98 110 defender that was brilliant.. go figure... Your not alone. Puma Growls At Me Constantly
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
note that LR changed the teeth design on the C&R of the back diff, make sure you get the latest
pics here: http://www.defender2.net/forum/topic13545.html If drivetrain backlash becomes an issue suspect diff also, found them to be the main cause of it (not R&P) 2 cents ![]() I you have identical sound on acceleration, check wheelbearings first, R&P tend to make more sound on overrun (or none under acceleration) |
Well took her in today, they are replacing both diffs, and both rear axles... Hmmm they said that the latest design is going in and shouldn't be a prob any more. Thaey also tell me that they have had a few with this issue, what exactly goes wrong is a mystery, but there is not much to a diff anyways. I am a diesel mech by trade and i personally tink that the carrier flexs ever so slightly and results in pinion to crown wheel tooth contact change which will cause excessive whine in overun and in some casses under load. It is quite simple to fix and if you want dead quiet running, have the crownwheel and pinion lapped by a machine shop.. But hey if its still under warranty let someone else do it ... Puma Growls At Me Constantly
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
wow, sounds like a good dealer. Have them check the clutch while they're at it ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Ummm already done that at 3000 klms, the front of the g/box fell to bits and took out the clutch etc. I would put my foot on the clutch and it would bang away. ... Sorry forgot to mention that in my firts post.. Puma Growls At Me Constantly
ULR port Melbourne Australia, i must admit they do help as much as possible... Havn't asked for a new one yet, but i nearly do anyway.. I havn't been in serious off road yet too scared it will break. Puma Growls At Me Constantly
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
Dealers will only change the diff now, ie swap it for a complete new (or more likely reconditioned) unit. There appear to be some issues with diff build quality from LR, and the ideal solution would be to set the diff up properly rather than simply replace one bad diff with another.
Setting up a diff is not difficult but is not a job for the faint-hearted; there are several other threads on the subject. Swapping a diff out is a quick job (you can do it in less than an hour for the rear, perhaps three for the front), stripping and adjusting one takes longer depending on skill, parts and experience. |
Yes i agree. I might pull the new ones out and re-check.... doubt it.
