Home > Technical > steering lock advise
passe partout
France 2000 Defender 90 Td5 HT Rutland Red
yes just joined and already asking for advise!
I have a 2000 TD5 90 with some weird alloys on that I've never seen on any other Landy let alone a defender. The tyres are BFG AT's 265x16 and our house has a drive with 2 really tight turns in it, consequently it rubs the tyres on the castor arms both sides.
I need more lock when I'm trying to get a trailer round the bends as it is a massive pain otherwise.
I'll do anything..... rims, tyres, spacers ??
Post #151215 19th Jun 2012 9:56pm
Have you adjusted the steering lock stops yet? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #151232 19th Jun 2012 10:50pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Won't help as poster has already stated that tyres are rubbing both castor arms. It would seem that what is needed are spacers or wheels with a different offset. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #151235 19th Jun 2012 11:02pm
I stand corrected. I see now of course you are right. Thumbs Up ____\We|Will|Win/___
Post #151238 19th Jun 2012 11:05pm
passe partout
Thanks for the advise and yes I would prefer to dump the rims than go the spacers route. What would work the best with those tyres?
Post #151252 20th Jun 2012 7:17am
leeds
Tyres rubbing arms equal max lock.
Keeping same rims and using a smaller diameter tyre will give more lock but at a loss of ground clearance under the diffs.
If you can not identify the rim put a photo up and someone might recognise them.
Take a wheel off and measure the distance from back of mounting plate to outside of rim will give you a measurement of offset if you know rim width.
If you are trying to reverse a trailer around tight bends then the smaller the wheel base of towing vehicle the better. Or consider a front mounted tow ball.
Brendan
Post #151280 20th Jun 2012 9:15am
Build a straight drive...if it's steep, which I expect because of the tight turns....engage lowbox on the way up...job's a fish Thumbs Up QRZ 2e0vpf
Post #151281 20th Jun 2012 9:33am
Merlin
Please remember this is a MOT failure...
Merlin
Post #151344 20th Jun 2012 1:00pm
passe partout
I've put 3 pics in the gallery.
Unfortunately the driveway has a sheer drop on one side so no go on that one.
Post #151416 20th Jun 2012 8:50pm
Tazz
Merlin
What? Having a steep drive, or a steering lock where the tyres reach the castor arms? Very Happy
Post #163058 19th Aug 2012 2:24pm
