Home > Puma (Tdci) > Mysterious plug
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Mysterious plug
Hi all,
I have a mysterious plug hanging next to the gear box/xfer box.
I initially thought it could be the diff lock connector but the light does come up when engaging diff lock. According to the service manual, the high/low range detection switch has at least 3 connectors, and I can see only two there.
So I am left wondering...:
- What's that plug?
- Why isn't it plugged?
- Where should I plug it?
- And if so, can I do that from under the car?
Any idea?
Post #150979 18th Jun 2012 6:09pm
bob neville
What year is the vehicle ?
I have a spare plug on my 2009 110 in the same location. It should be clipped to the gearbox and was removed in late 2010/2011 MY's.
2013 Defender 90 CSW - sold
Post #150983 18th Jun 2012 6:25pm
o4dn
Bob
Ah, yes indeed, mine in MY2009!
Post #150994 18th Jun 2012 6:49pm
excossack
Do 2009 MY Landies have a sensor for detecting when you engage low box? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #151018 18th Jun 2012 8:04pm
PaulMc
I'm pretty sure that connector is C0100, for the driver's seat belt buckle switch, which isn't fitted to all markets.
There should be two wires - White/Purple and Black.
. Paul.
Post #151034 18th Jun 2012 9:01pm
o4dn
Thanks all for the replies! Thumbs Up I feel relieved now...
I am pretty sure it does as engaging low ratio does change the ECU mapping and throttle sensitivity.
It does not have any indicator on the dash though, but for sure the ECU can tell when the low ratio is engaged.
That would match what I can see, but hard to tell with certainty given the amount of Waxoil spread out in the area Whistle
Post #151142 19th Jun 2012 4:18pm
Caterham
Just looking at workshop manual and item 24 is the low range indicator ???.
Mine only seems to have diff lock indicator which comes on in low..... I presume this is normal?
Post #339898 22nd Jun 2014 8:14pm
munch90
the diff lock light sort come on with diff locked in high or low range
Post #339903 22nd Jun 2014 8:22pm
Caterham
Just done a search and been and checked all normal...no indicator for hi / low just for diff lock Thumbs Up
Post #339905 22nd Jun 2014 8:27pm
