![]() | Home > Maintenance & Modifications > Top tip: Measure your bolts!!! |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
lucky you had a spare!
i got a mantec dural one for the 110...must fit it one day....using the right bolts ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
Its a nice guard. Just check the top bolts! I used the long one in the end but cut thje end off with the angle grinder.....easy when the rad and intercooler are out on the floor!
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
At least you know you have good tools
![]() ............................................................. Earth first. Other planets later |
Top tip Jamie -
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
thats unlucky, glad you had a quick solution. Cheers
