![]() | Home > Maintenance & Modifications > Where to hide an amp on a 110 station wagon? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20983 ![]() ![]() |
Behind the cubby box if you have one or in one of the seat boxes? The drivers seat box has lots of room. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 ![]() ![]() ![]() |
Underneath the cubby box.
Yep, another good suggestions providing it has sufficient ventilation. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
good one AA. That's where the OEM Clarion subwoofer is fitted on the SVX. It's a dead good location to get wires to under the carpet to behind the dash, and will raise the cubby up a bit making it more comfortable for arm resting purposes! pete |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
I've been having the same issue with my double cab, there's just no space
![]() I really want to use my 2 JL Audio Slash amps and as many of the 3 x 10" subs I have... but they just don't fit under the rear seats ![]() |
This is where the amps with the smaller footprint come in to their own whilst still not small as such it helps a lot. I have been looking at dimensions of some tonight and some are huge
Yeah the Slash is a big bit of kit, but many in the audio world still think its the best even being nearly 10 years old
![]() Might just need to give in and fit the lot in my partners Astra ![]() |
Bloomin hell just looked up the dimensions of those and I thought the one's I looked at wouldn't fit ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 ![]() ![]() ![]() |
I'm mounting my JL Audio amps next week in the back of my 110. I'm going make an inclosure for them and mount on the arches behind the rear seats. Just got to give them enough ventiltation! I'm also fitting my ZR components in the front. Should sound good! ![]() Agreed they're still seen as one of the best amps you can buy. 2008 110 XS CSW Stornoway Grey |
With the parrot head unit you can squeeze an amp in
Behind - neat |
As you say, the wires are well hidden. I got one of the boxes below the cubby box and underneath that a subwoofer installled, which required certain creativity to fix it properly, but that way the cubby box has the same height as the door. Both arms rest in an equal height now. Winding roads need some proper posture of the driver in order not to hit the cubby box with the ellbow (my right one as driving on the right side of the road). |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Luckily you do not have this
http://www.vibeaudio.co.uk/car/blackdeath-...th-reaper/ ![]() Click image to enlarge ![]() ![]() ![]() ![]() I went with an amp under the cubby box - anyone who is at the Bristol & Southwest feel free to come and have a look and listen! Focal 2 way components in the front Focal 3 way components in the rear Focal sub Rockford amp Alpine HU LOTS of Dynamat |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
.......can i bring my 80's CD's next weekend TIM...might pop down unit later and have a quick look n listen...see the wheels are on... Putting Dreams on Drives at JLR Solihull.. |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
in a 110 ada? |
