![]() | Home > Puma (Tdci) > New technical bulletin regarding brake vacum pump (LTB00177 |
red Defender Member Since: 11 Feb 2008 Location: Cornwall Posts: 76 ![]() ![]() ![]() |
Having replaced several vacuum pumps I was keen to ensure the replacement pump on my 09 Puma was the latest available. There is some confusion with the latest tech bullitin, as shown by Eduardo. The latest version of the pump has been in production since late January 2009. The bulitin says it should be 148** but LR didnt tell the makers. Therfore pumps are still being manufactured with the old number 12384. After the number there is a date code, eg 31D09, this would be a pump manufactured 31st April 2009 and would therefore be the latest version.
My origional pump failed at 5000miles and the new one has survived 2000, so hoping the problems solved. I still carry a spare all the time, and can change it in under 20 minutes. Whats broken now ? |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
there are actually 3 versions.
The 2nd replaced teh 1st and went straight to protected stock in the UK and couldnt be ordered...in theory if you have one of these fitted off this list (i have) then its the latest as these were check and distributed centrally specially. The 3rd has not long been released. Mike |
Had mine replaced today the dealer says its the latest version
Whats the LRO no on the pump. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
Hi bud its a 30 G 09 Does that help ![]() |
Looks like the latest mate. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
Cheers bud
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
Hi, my brake vacuum pump begins to lose oil, not too much, but there is a slight halo near the pulley.
My 110 is of January 2009 and it has 33.000 km now, do you think I can require the substitution from LR? Matteo Defender 110 Td4 SE MY 09 |
If its leaking take it to the dealer they will replace it for you
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
so, i am welcoming to the club
![]() should i try for replacement ? my def was manufactured at '07, so i suppose it is the first ''edition'' of pump. ![]() |
