Home > Puma (Tdci) > EML FAULT ????
marcoegyptos
France
EML FAULT ????
Hello, I am new in the forum
I have a 110CSW Defender bought in June 2007 and I have a strange problem , when I fill the fuell tank , the EML light appear and canno't be reseted except by the dealer.
It's been back to the dealer 4 times already for EML problems.
When the light comes on, the engine power is ok and I don't have any problem except the light of the EML
Last time the Dealer has changed the flowmeter but when I fill again the tank , the EML fault appear again and the fault code was P11-03-00
Air Floweter in the range but more high than previous.
If any one can help me ?
Post #15003 3rd Sep 2009 1:35pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I've not heard of this one before.
Does it only happen when you fill the tank right to the top?
Welcome to the forum, by the way. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #15010 3rd Sep 2009 2:21pm
dgardel
Italy
P11-03-00: Air Floweter in the range but more high than previous.
Normally is a code related to the EGR Valve (when doesn't open, mass flow read more airflow than expected).
Post #15016 3rd Sep 2009 3:15pm
marcoegyptos
France
Yes this happen when I fill the tank but not to the maximum.
Shall I change the EGR vavle ???
Post #15017 3rd Sep 2009 3:50pm
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Hi,
Could be the sender unit in the fuel tank or it's connection along with dodgy earth!!!
Good luck
JLS
'El Pepe Flamenco' JLS
'El Pepe Flamenco'
Post #15025 3rd Sep 2009 5:34pm
marcoegyptos
France
Thank you for the answer.
What is the sender unit ? I can't understand
Post #15052 3rd Sep 2009 10:45pm
marcoegyptos
France
I understood now what is the sender unit.
I don'think , it is a problem of sender unit because if any problem appear I will have a fault with error code.
As I know when there is a problem of fuel is only when the tank shall be empty (10 liters) the low fuel lamp tank appear after when the tank reach 7.5 liter the fuel indicator is in position 0.
When it reach 4.5 liter the ECU start to make motor problem for 1 mile and stop the motor after that.
I am thinking about a problem of air entrance from the gas cap.May be I have a problem with the event pipe ??
Post #15056 4th Sep 2009 6:19am
jlerra
Hi Marco....,
The sender unit is connected to the lamp on the dash and subsequently to the electronics ECU,etc.
The fuel level anomaly would indicate a possible problem with the float, resistance in relation to the fullness of the tank.
Worth investigating even though the fault diagnosis error is different.
Suggest to your dealer!
Warm regards
jlerra
'El Pepe Flamenco'
Post #15058 4th Sep 2009 7:29am
marcoegyptos
France
Thanks Jlerra
I will inform my dealer to have a look but he shall dismantel the tank for that ?
There is any relation with the air flowmeter fault code ??
Post #15060 4th Sep 2009 7:48am
jlerra
Hi Marcoegyptos,
No need to dismantle the tank as the sender connections can be approached for inspection from the top.
It may be that the error you experience may not be registering. But it seems that maybe if it's a problem with fuel volume and the light coming on - the sender potentiometer may not be functioning satisfactorily.
Worth your dealer having a look!
regards
jlerra
'El Pepe Flamenco'
Post #15123 5th Sep 2009 8:38am
Bogblaster
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
I get the code frequently, I bought a reader / reset tool but it is always the same code. My EGR is blanked, but I had the problem before then. I put it down to the ITG air filter. No tune, but bigger intercooler, de-cat exhaust and ITG.
I use this http://www.scangauge.com/features/scantool...4wod5HwDKw
to read and reset.
I would say though that I only turn the light on when taking it steady Shocked If I hoon around like a madman it never truns on!
BB 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW
2016 90 Adventure
Post #15124 5th Sep 2009 9:46am
marcoegyptos
France
Thanks for the informations
This fault , I got from 2007 (500kms), in 2008 I tuned the DEF and added a big intercooler, I still have the same problem.
Last month I bought a FAULTMATE MSV-2 for reseting the fault.
I think as I read in the forum I will blank the EGR but I will add an opening to keep the air flowmeter running
Post #15126 5th Sep 2009 9:58am
