Home > Puma (Tdci) > Diagnostic systems
oldyella76
Australia 2012 Defender 110 Puma 2.2 SW Indus Silver
Diagnostic systems
Could someone advise if the diagnostic system for a 2012 2.2 litre defender is the same as the 2.4 litre 2007 to 2011 models. Just wondering if the hardware/software is the same.
Thanks. Lindsay
Post #149874 12th Jun 2012 9:53am
bell-auto-services
The faultmate FCR supports the new 2.2 for read and clear faults.
Pete
Post #149884 12th Jun 2012 10:55am
oldyella76
Thanks Pete, What I really want to know is the software for a 2012 puma with a 2.2 compatable with a 2007 puma with a 2.4 motor. In other words can I use the same diagnostic Nanocom on both vehicles.
Lindsay. Lindsay
Post #150074 13th Jun 2012 7:57am
bell-auto-services
At the moment their isnt a tool that has both models in one, soon the nanocom will but at this moment the 2.2 is not added to the firmware for it.
pete
Post #150095 13th Jun 2012 9:16am
oldyella76
This maybe the problem I have bought a nanocom for my 2.2 and it won't work. They tell me there is something wrong with the OBD plug on the vehicle. I suspect that it wont work on my 2012 2.2 litre.
Lindsay. Lindsay
Post #150132 13th Jun 2012 11:55am
the ultragauge should be fine, and at £65 a pop, well worth the money .. do a search Brian/Lorryman did an excellent write up with lots of photos Thumbs Up
Post #150142 13th Jun 2012 12:47pm
bell-auto-services
Lindsay.
Hi
Ill explain a little more as I was a little breif with my previous posts due to not knowing the full situation.
The 2.2 Puma PCM read and clear fault codes will work on the existing nanocom evo though its not officially yet fully supported. The 2.2 pcm structure and process are slightly different in comparison to the 2.4, as an example the 2.2 ecu reports various things differently to the 2.4 like that its sometimes busy with internal calcualtions when we want to read the faults so the nanocom as now may show a fail comms message or simlar.
However, for the moment until the official update to the nanocom is made you can still use the function as if it were a 2.4 which is what the nanocom supports currently but it may take a few attempts to log in and read faults due to the differences between them etc. Once we have finished the full developement we will have an update available for the nanocom that will add the 2.2 protocols and also will give the relevent live data info to match on the inputs pages etc.
This is in developement now and we hope to have something finalised very shortly as a form of an update that will start official supported coverage for the 2.2.
Pete
Post #150162 13th Jun 2012 3:07pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
The software is slightly different, but i.e. our Kiwi PLX works on the 2.2 as for the 2.4. Never forget: cars have owner, Landrover have field service personnel.
Post #150289 14th Jun 2012 10:24am
chrisbowler
AUTOLOGIC does both as separate menus!!!
Chris Bowler
Post #150398 14th Jun 2012 11:11pm
wslr
10 Grand for Autologic may be too much to spend for the average owner though.
Post #150478 15th Jun 2012 3:53pm
