![]() | Home > Technical > Remap Interface |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
EDITED
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684 ![]() ![]() ![]() |
Nope. As a side note, can one use the AlienTech remap unit on other vehicles? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Hi Brian, the interface should not make any comms with any module untill a button is pressed. Pete |
EDITED
Im not sure i fully understand what you are trying to get to the bottom of but ill try and help if i can, if you plug the interface into the obd port it does not send any diagnostic traffic to any ecu until a button is pressed ? Sometimes the bus will go light from the resistance change as a new obd device powers its self and sometimes heavy after but no traffic diagnostic is sent until you press a button or function.
;$FILEVERSION=1.1 ;$STARTTIME=41072.4831475498 ; ; C:\Documents and Settings\Administrator\Desktop\2.4-TDCI-PCM ; ; Start time: 12/06/2012 11:35:43.9483 ; 500K Diag ; ; Columns description: ; ~~~~~~~~~~~~~~~~~~~~~ ; +-Message Number ; | +Time Offset (ms) ; | | +Type ; | | | +ID (hex) ; | | | | +Data Length Code ; | | | | | +Data Bytes (hex) ... ; | | | | | | ;---+-- ----+---- --+-- ----+--- + -+ -- -- -- -- -- -- -- Last edited by bell-auto-services on 12th Jun 2012 12:55pm. Edited 1 time in total |
Here is what happens when you plug the obd interface in with key off as i suspected it would due to the resistance change. This was made with NO filters set so all CAN traffic would show in the trace if it were coming from the Allientec interface.
Its possibile like on a D3 that an other module is watching the bus for traffic but leaving the logger on for over 10 mins no traffic is sent or received so i would assume all modules are asleep and not looking on the bus. At least when the key is off anyway. ;$FILEVERSION=1.1 ;$STARTTIME=41072.5233123414 ; ; C:\Documents and Settings\Administrator\Desktop\bus heavy.trc ; ; Start time: 12/06/2012 12:33:34.1862 ; ; Columns description: ; ~~~~~~~~~~~~~~~~~~~~~ ; +-Message Number ; | +Time Offset (ms) ; | | +Type ; | | | +ID (hex) ; | | | | +Data Length Code ; | | | | | +Data Bytes (hex) ... ; | | | | | | ;---+-- ----+---- --+-- ----+--- + -+ -- -- -- -- -- -- -- 1) 7537.9 Warng FFFFFFFF 4 00 00 00 04 BUSLIGHT 2) 7538.1 Warng FFFFFFFF 4 00 00 00 08 BUSHEAVY |
It is normal CANBUS wakelock (google CANBUS theory)
it can be generated from the single ecus itself or by changes of BUS status or by changes of ECUs status or by......................... http://www.gaw.ru/data/Interface/CAN_BUS.PDF Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
http://www.can-cia.org/fileadmin/cia/pdfs/CANdictionary_v6.pdf
http://www.actel.com/ipdocs/CANbus_lic_RS.pdf Nice to read http://www.interfacebus.com/CAN-Bus-Descri...tocol.html http://www.bosch-semiconductors.de/media/p...d_spec.pdf http://www.bosch-semiconductors.de/media/p...can_fd.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
EDITED
EDIT
Brian in my personally opinion is only a "bug" on sync SW subroutine inside the EMS that do not syncronize well (or do not sync at all) the IC and/or spurious signals on ECM in/out...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License Last edited by dgardel on 14th Jun 2012 11:58am. Edited 1 time in total |
