Home > Tdi > Engine noise defender 300 Tdi |
Morea Member Since: 20 Jan 2011 Location: Asturies Posts: 201 |
Hey. I'll put some videos of the engine from a friend to see what you think. We are like crazy behind the noise TATATATATATATATATA there no way to find its origin. He did all this:
This engine was made in the wake of the sound, adjustment of tappets, proof that the plucked and drop nozzles 1-1 did not change the sound, also removing the vents, and disconnecting the positive injection, even so was still ringing the same TATA Thinking it would be plain rod or something, change this by another motor also recently rectified aprobechando same, manifolds, turbo, new clutch, new motor plugs, new accessory belt, pump new direction, well, because once started following the same sound, exactly the same. With mounting, remove the accessory belt, see whether it can be a pulley, nothing we break the top of the distribution, is ahead of a tooth, nothing, no delay, you change brake depressor, nothing, adjustment of tappets to perfect 0.20, remove air filter anything, let go with 1x1 pulled the injectors, no, we changed the injectors by the discovery of 300 that goes round your injectors, and tested on this engine and all. Sorry for my English if not understand well what you mean. Thank you. http://www.clublandrovertt.org/index.php?a...ype=avatar |
9th Jun 2012 2:39pm |
ISTR a similar sound on my old 300tdi Discovery leading to replacement of the vacuum pump. Darren
12th Jun 2012 9:07am |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 |
Also cured a similar noise on a 300 tdi by replacing the servo vacuum pump. You need to get a long solid bar (long screwdriver for example) and place one end to your ear and CAREFULLY move it round the engine placing the tip on different components till you identify where the noise is loudest. Bit like a stethoscope. The other obvious culprit may be a hole in the exhaust manifold gasket.
Good luck, let us know if you cure it. |
12th Jun 2012 9:25am |
Thank you very much. He informs my friend and we'll look this week. http://www.clublandrovertt.org/index.php?a...ype=avatar
12th Jun 2012 10:37am |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
Yes I think its the vacuum pump making the noise, but DO check the servo body first. I was going to replace my vacuum pump a while back, but couldn't be sure thats what it was. Fixing the leak has fixed the noise, and the pump is now quiet, By all means replace the pump, but check the servo first.
12th Jun 2012 5:30pm |
Solved, it was depressing. Many thanks to all http://www.clublandrovertt.org/index.php?a...ype=avatar
24th Jul 2012 9:10am |
WELL? What was it after all? |
24th Jul 2012 8:01pm |
The problem was detected with patience and with a noise detector, now time to go ride and look good. When you have finalized it will notify you. http://www.clublandrovertt.org/index.php?a...ype=avatar
24th Jul 2012 8:18pm |
