![]() | Home > Td5 > Brakes failing?? |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
apart from the master cylinder I would also check for a sticking caliper, especially at the rear. BM52
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8337 ![]() ![]() ![]() |
or loose caliper bolts Cheers
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5980 ![]() ![]() |
Check your wheel bearings
Andy |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
+1 Especially the front ones. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 625 ![]() ![]() ![]() |
Thanks for the replies, but, what effect can wheel bearings have on the brakes? |
If the bearings are gone, the discs wobble and push the pads back in, so they need to travel further when you press the brake...
My guess is your abs block is goosed...like mine was ![]() |
Thanks all, found the culprit, it is the offside rear caliper, seized on me whilst going to work again. I carried out a quick check the other day and all appeared ok but then out of the blue there was a grinding noise coming from the back, jacked it up and all was revealed
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
Just did my rear brakes, here is the kit list (I know you didnt ask, but in case you find it useful..
![]() 1. Rear Brake Discs LR017953 £120.92 PAIR 2. Rear Brake Pads SFP000270 £50.74 3. Rear Brake Calipers RH LR005952 £122.05 LH LR005950 £142.38 also a £30 surcharge on the above caliper so old one will need to be returned 4. Any hub seals etc that I need to replace when removing brake discs FTC4785 X 2 £7.38 pair 571752 X 2 £1.62 PAIR 5. Anything else I need when replacing complete rear brakes..! RFD100000 X 2 (Hub lock nut) £7.86 PAIR FTC5241 x 2 (Hub lock washer) £3.48 PAIR My calipers were siezed and the pads themselves were crumbling, I dont do much mileage, so it think it was just down to lack of use and crappy weather..! cheers simon ps Sorry, should have said this list is for a 2001 TD5 with ABS/TC, not sure if that makes a difference.. |
Thanks for the info Simon, I was hoping the calipers would have just required cleaning and free-ing up a bit, they were worse than I thought, the one side was seized solid and no movement of the cylinder/piston at all, I'm on nightshift this week so they will be coming to work with me and a full overhaul with stainless pistons to be fitted. Hopefully that should be it
