![]() | Home > Puma (Tdci) > 110 sw Puma, Broken tube – but what is it? |
rasmussen Member Since: 13 Mar 2012 Location: Nice Posts: 46 ![]() ![]() |
Just realised a broken tube in the rear left wheel box – just above the exhaust pipe.
![]() Click image to enlarge ![]() Click image to enlarge Could anyone educate me on what this piece of pipe is. Looks like some sort of ventilation? Is it difficult to install a new one? Cheers, |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
looks like an axle breather possibly
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
fuel tank breather tube, axle breather is on the A frame
Keith |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
As Keith says, it's the diesel tank breather ..
they are supposed to be tucked behind the plastic plate in the background
BP - is it not in a clip at the very top???
Obviously missed its recall .... ![]() |
it's worrying how low down that is then
Thank you very much for your comments
![]() I have tried to find this part but very difficult to find. I only found this: http://www.brit-car.co.uk/product.php?xProd=160379 but over 30 quite ![]() ![]() Have anyone experience with ordering parts directly from brit-car? |
I use Brit Car all the time for parts. Never a problem but can take a while to send as they supply a lot of genuine parts that have to be ordered.
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Just buy a bit of fuel pipe that is the correct diameter, and use a jubilee clip to join it to the original rigid section, that has the one way valve.
Andy |
And extend it higher .... |
oldyella76 Member Since: 26 Feb 2012 Location: Huntly Posts: 7 ![]() ![]() ![]() |
I joined mine to length nylon fuel line and ran it along the top of the chassis rail to the engine area and put it up high against the firewall then joined the valve to the end of it. When you wish to bleed the fuel system just blow a bit of compressed air down the tube and it will prime the system for you.
Ragards Lindsay. Lindsay |
And move the pipe behind the plastic plate.
There is a recall for it. In that positiin you can have water/dirty ingress inside the tank and future problem with the water up tu damage the common rail high pressure pump and injectors. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
