![]() | Home > Maintenance & Modifications > fuel additive |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
what fuel additive is best to use.?
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Forte is a good product. link to some below on Ebay.
http://www.ebay.co.uk/itm/FORTE-ADVANCED-D...41667580d2 |
what about adding T2 as well ?
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
I use Miller's Diesel EcoMax in my Td5, definitely makes a difference. Engine runs smoother and quieter and seems to pull more readily. Use it in the Golf as well and gives around 5mpg benefit going by the computer read out. 2005 Td5 | 90 Station Wagon | Tonga Green
as Pete says, I use it the same as we do in the Jaguars at work ![]() 1968 1/32 scale Britains 109 Pick up. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
2 stroke. We are still debating here as to it's benefits, if any. I find it makes the engine run very smoothly. Can't say if it benefits mpg but as the vehicle goes for it's first mot on Thursday I'll find out what it does for emissions. 1982 88" 2.25 diesel
spudfan
let us know how it goes ,thinking of using t2 FC but not sure if there are any benefits or not. ![]() |
Use it in my Puma, have done for over 3 years....a lot smoother and a couple more MPG. ![]() Treat every day as if it is your last....one day you will be right!! |
Will do. I'll be interested in seeing the emissions results myself. Thursday is the day. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Mine was done last week, use 2 stroke oil.
Fast pass limit is 1.5m (-1), mine came in at 0.29m (-1) ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Smoke result came in at 0.750/m.Everything went O.K. 1982 88" 2.25 diesel
I use 2 stroke too ... 200-400ml per tank
I also use BP Ultimate every 4th tank ![]() |
Although the vehicle passed and the pass limit for smoke is 3.0/M I thought my reading would have been even lower.Last year the 1992 200 tdi had a reading of .150/M with 2 stroke. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 ![]() ![]() ![]() |
Hi All WHY? I have read several threads on this and other forums about what additives to use but why do you use them? Is there any actual NEED for an additive, personally I never use them as I believe that the fuel is fit for purpose and the Land Rover dealer sees no reason for people to use them so are you just throwing more good money into your tank for any good reason? |
