Home > Puma (Tdci) > Steering Guard advice
AlisterC
Wales 2011 Defender 90 Puma 2.4 XS CSW Indus Silver
Hi All
Did a search and couldn't find what i was looking for
I want to fit a steering guard to my 2011 Puma, and would like your thoughts on which is the best one to go for
How easy are they to fit?... is drilling required etc?
Steel or other?
Many thanks in advance
Post #149363 9th Jun 2012 1:15pm
I don't think you will find there are any that are bad as such. There should be no drilling involved and should be all just bolted together. Also bear in mind the difference between the alloy guards and the steel guards. Steel will be much stronger but heavier but the alloy the other way around. I personally have a Rebel 4x4 galv steel one strong as you could ever get and have never ever had a problem with it. Only around �60 - �90 mark too.
There is also two towing eyes on each side.
http://www.rebel4x4.co.uk/steering_guards.htm _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #149372 9th Jun 2012 2:08pm
kjmeijer
Netherlands 2016 Defender 110 Other SW Galway Green
I had the aluminium steering guard from www.offroadservice.de on my 2003 90 and have put the same one on my Puma. Quality and finish are super. Fits without drilling etc.
Post #149376 9th Jun 2012 4:00pm
leeds
Re: Steering Guard advice
AlisterC wrote:
Hi All
You will NOT get any consenus of opinions about what is the best steering guard to go for.
Have heard various arguments from you should not need a steering guard, stick to LR steering guard, use Sumo/Dan bars with or without uprated TRE, plate steering guards act like a plough etc when being recovered backwards.
What I would suggest however is that you avoid the el cheapo/ebay ones like the plague. That is unless you are rich and can afford to buy cheap and replace them.
El cheapo one failed at bolt holes on both sides after about 6 'gentle' recoveries
Brendan
Post #149391 9th Jun 2012 5:49pm
Zagato
You pay for what you get, the thicker gauge ones are recommended, galv steel brackets and ali protective plate is a good combination apparently, also consider if you want built in recovery eyes or not Thumbs Up
Post #149393 9th Jun 2012 6:40pm
AlisterC
Thank you for your answers folks.
Guess I'll start taking a look around at the options you've given me.
Brendan... Agree with you regarding quality. This is something I want to fit once and once only
Post #149399 9th Jun 2012 7:29pm
dgardel
Italy
SVX one
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #149420 9th Jun 2012 8:48pm
leeds
Have seen many different types of steering guard so rather then just say buy brand X here are a few points to consider.
Recovery eyes are they built in?
If not is it compatible with Jate rings?
Or have you got recovery eyes on your bumper?
Do you need a 2" receiver for moving trailers around/attaching a demountable winch to?
Is the steering guard hot dipped galvanised or electro plated? Hot dip gives more rust protection.
Is there plenty of metal around bolt holes?
Do you need lights built into the steering guard?
Will your steering guard be compatible with anything else you want to mod on your vehicle?
Brendan
Brendan
Post #149422 9th Jun 2012 9:04pm
dgardel
Italy
The Mantec one and Land Rover. One have an internal.frame Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #149430 9th Jun 2012 10:33pm
AlisterC
Really useful information guys, thank you
I think I want to go for super sturdy with recovery eyes... Now the search begins!
Post #149455 10th Jun 2012 9:42am
That'll be steel then Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #149456 10th Jun 2012 9:48am
K9F
Nice intercooler grille Dgardel.... Thumbs Up Like the steering guard too, same one I've got.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #149477 10th Jun 2012 12:42pm
Mal,
Are you sure your's isn't a chrome jobby Wink Laughing Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #149479 10th Jun 2012 12:47pm
K9F
forum-member formerly known as Konabikes11 wrote:
Mal, Are you sure your's isn't a chrome jobby Wink Laughing Thumbs Up
Corrected your name Laughing Definately not chrome! Not yet anyway! Only disadvantage with SVX one is that there are no recovery eyes.
Post #149483 10th Jun 2012 1:16pm
it was k for Kona I had. Not capital K for ease of logging in Rolling with laughter Know what you mean with the recovery eyes though. Mine has four all together what use four is I don't know but good back up I guess. Not that I ever want to be pulled out anyway Whistle _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #149485 10th Jun 2012 1:18pm
