![]() | Home > Puma (Tdci) > Wiper blades |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10384 ![]() ![]() |
Genuine or go to your local factors and ask for the best quality. Avoid the gimmicky blades
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Nothing to do with the blades, unless it only occurs on dry screen - rubber sticking - more likely to be the "gearboxes" for each wiper. Had mine replaced eventually - was intermittent at first and only after 15 mins use - but replaced under warranty and now silent. Joy.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 ![]() ![]() ![]() |
Mine make a clack noise on direction change as well... It's the blade hitting the rubber under the windscreen. I found a bit of tightening (although a new gearbox may be best if under warrenty) sorted it out.
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
Silblades from Mud. Top kit!
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
I'm using Halfords wipers on mine - but with the built in water jets that I made myself from a Nissan Cabstar truck
![]() Works great ![]() Click image to enlarge ![]() Click image to enlarge |
Portafilter Member Since: 08 Aug 2010 Location: Melbourne Posts: 27 ![]() ![]() |
Hi Maxxed,
do you have a tutorial or post on how you did this ? looks like its well worth the time and effort. Best Justin |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3496 ![]() ![]() ![]() |
Am gonna have a look at this.........gearboxes. Funnily enough was watching them closely while sitting in traffic on the M25 and started to think it wasn't the blades......... 1951 80" S1 2.0
It there's enough demand I'll be making kits to order ![]() |
Just lifted them up and they are loose from one direction to the other.......... 1951 80" S1 2.0
I pushed for this at the service and yes, all done under warranty, big thanks for the advice WelshGas 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
See here for blades http://www.ebay.co.uk/itm/200817138634?ssP...563wt_1399 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
familymad this is quite a common problem. Mine has been the same from new - 'clack clack clack'. When it was serviced last week the dealer said there was 'excessive lateral movement' and new wheelboxes are on order - under warranty of course. Most dealers will be familiar with this so I'd get it checked out
Glad you're sorted Familymad.
![]() ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
