![]() | Home > Td5 > Rear door pre/post 2001 swap |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6217 ![]() ![]() ![]() |
Fits straight over. Hinges are the same but the lock assy is different. you'll need to play with the wiring a bit, as the newer one has a different plug on the wiper/heated window loom, but you can just remove the old loom and swap it over to the new door.
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
I have this to do as soon as possible because my wee is particularly fed up of the new door being proper up in the kitchen. ............it's only been 6 months.
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
Thanks, is the wheel carrier different too..? I currently use a separate wheel carrier, but may go back to a door mounted carrier. Cheers Simon |
Yes, the wheel carriers are different (the later Td5 door carrier looks like a discovery one)
If you've got a separate carrier frame, i'm sure you could fabricate something to make it fit the newer door. |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
Have a read of this Simon. The related posts at the bottom cover fitting, wiring etc etc.
http://www.landroverexpedition.com/technic...-td5-door/ HTH Steve |
Brilliant, thanks Steve....
No problem.
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
Anyone done the next step where they have a 300tdi loom and have fitted a Td5 rear door and the later Td5 dashboard, re the different way the switches are wired ?
marsie Member Since: 18 Nov 2011 Location: sheffieldish Posts: 535 ![]() ![]() ![]() |
Planning on doing the same door upgrade to mine when i find one for sensible money
![]() Paul ![]() |
The one piece door is supposed to be stronger and hold up better. ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
