![]() | Home > Maintenance & Modifications > Rear view mirror arm bracket question re monitor replacement |
| Brocade Member Since: 03 Apr 2012 Location: London Posts: 9
Folks,
I am planning to replace the rear view mirror with a monitor and need to choose a bracket...the Chinese manufacturer gives me the following options: http://www.gbeshop.com/InfoBase/downloads//metal-brackets.xls Could someone recommend which of these I should use as a replacement ? Thanks in advance |
This is for a Puma Defender 110 by the way
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
It may be my stupidity but Land Rover isn't listed at all, most of the depicted appear to have four mounting holes too, so I would have to say "none of them" or just pick one and adapt it to suit. It also depends on the size, weight and mounting of the monitor you are fitting surely? If you go through life with your head in the sand....all people will see is an ar5e!!
It must be me? Sigh..... Ok then! Definately #2! Sorted! Treat every day as if it is your last....one day you will be right!! |
