![]() | Home > Wheels & Tyres > Put wheel spacers on - now got steering wobble at 55mph |
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 ![]() ![]() ![]() |
Thanks Porny, that is the route of the problem - I am sure. For the moment they are off my Landy so problem gone away. Put them on ebay - maybe someone with steel wheels will be better with them. 110 Hard top
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205 ![]() ![]() ![]() |
I have a pair of these spacers (without the lip) and also got wheel wobble.
Eventhough the alloy nuts neatly fit perfectly into the wheel, there is a little slack which i agree could cause a mis-alignment. |
shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160 ![]() ![]() ![]() |
where would one find a pair of hub centric spacers?? Land Rover's don't leak oil, they simply mark their territory!
I found a guy who will machine up a set of hub-centric spacers for me (£80.00 full set) but needs the correct dimensions. Would anybody know the dimensions required on the form below. If not Ill have to subside my laziness and pull the wheel off and measure.
Well I ordered another set with the locating rim - hub-centric
![]() I know some people will never learn ![]() Going to fit them when I can, I really much prefer the look of my Landy with them and they drive better - wobble aside of course. Will keep you posted ![]() |
expedition Member Since: 11 Sep 2009 Location: Vercelli-ITALY Posts: 75 ![]() ![]() ![]() |
I too am having trouble balancing with Modular brasialian iron wheels and tires 255/85 R16 BF MUD.
Try and try you can not have a perfect setting. The offset takes me into the tire outside the fender line, so not too much but that flared with the originals. ![]() 110 Td4 MY07 "E" Keswick Green |
