Home > Puma (Tdci) > manufacturing defect! pics!
AdrianCR
2016 Defender 110 Puma 2.4 XS CSW Scotia Grey
I appreciate all the help you can give me regarding my problem. Does this problem need to be repaired?
Big Cry
2009MY station Wagon roof problems
Greetings from Costa Rica
Post #148165 1st Jun 2012 6:24pm
Killer90
Site Sponsor
it happens on most of them all it is is were the two pieces of the roof meet and the paint splits, personally i would take it back if you still have warranty Thumbs Up
Post #148166 1st Jun 2012 6:30pm
AdrianCR
I have no warranty left. may eventually enter water? Thank you very much!
Post #148168 1st Jun 2012 6:39pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
mine (2010 110 DC) is like that...
no water inside though...so far...
but the dealer said they fix that, and it all happens again...and it did... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #148169 1st Jun 2012 6:46pm
Get some decent white panel sealer (or silver if available)
Good smear in there will seal it.
Post #148186 1st Jun 2012 8:02pm
Killer90
Site Sponsor
yer as jim said seal it off and then get a brush out and touch it up the same colour as the rest of the vehicle, you wouldnt tell and just think it will be a better job than what LR do Thumbs Up
Post #148189 1st Jun 2012 8:38pm
Happyoldgit
If I were you I'd carefully clear out as much of the old sealant then inject something like Sikaflex or Tiger seal, smooth off while 'wet' off and when dry carefully repaint / touch up to match the paintwork. Steve.
http://forums.lr4x4.com
Post #148210 1st Jun 2012 10:29pm
Grockle
right then your lot,I repaired ours with dum dum(body corking) pushed into the crack and carefully wiping off the excess with contact cleaner fluid,it remains flexable so shouldn't crack again.
I also repaired the guttering where a piece of the 'filler' had dropped out, I was even able to touch it in with a touch up stick to colour code it. Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #149608 10th Jun 2012 8:51pm
Zagato
Shocked didn't realise they crack as bad as that... you can see the strain the front roof panel is under when it's fitted in the factory...I would be looking to do what MOG has suggested as a more permanent solution Silkaflex is like concrete and Tiger seal will stay in place whilst the metal around it cracks it's so strong.
Post #149699 11th Jun 2012 9:43am
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
My 12mth old car is just having it's roof resprayed under warranty due to this fault Shocked I get the feeling it maybe getting done just before the warranty runs again! Darren
Post #150228 13th Jun 2012 10:45pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
First, yes it needs to be fixed, or you get corrosion underneath.
Second, clean it, let it completely dry out, seal with sealant like Panthera (better then Sika or similar), smooth sealant with dishwasishing detergent on the finger tip, wait and clean, spray paint again - w/o the sealant it will crack again. Never forget: cars have owner, Landrover have field service personnel.
Post #150287 14th Jun 2012 10:22am
AdrianCR
To all thank you very much
Post #150569 15th Jun 2012 11:48pm
