Home > Puma (Tdci) > 2.2 or 2.4 ? and other questions
Page 4 of 4 <1234
mudrut
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Reading this thread, its interesting to see the wildly varying views on the the Puma vs TD5 (even though the thread is about the 2.2 vs 2.4)
I have always thought that the 6 speed box in the 2.4 was a big improvement on the TD5 5 speed. I find that the TD5 runs out of gears fairly readily and benefits from an overdrive or some other method of gaining longer gearing. If I am looking at buying a TD5 Defender, I kinda add that cost on in my head.
Don't get me wrong - I adore my TD5 vehicles and love the buzziness of the engine (especially with BAS remaps in both), but the anti-stall of the 2.4 is almost infallible.
The 2.2 though? Despite the paper figures, I am an old-fashioned 'no substitute for cc' kind of guy. If the only reason that the engine has be downsized is to fit the EU regs, then it wasn't done for performance or to benefit the drivability of the vehicle. I kinda had this idea that I would buy a Defender in the last year of its production run, but don't see that happening with the new engine.
regards
Ian
Post #147032 25th May 2012 2:00pm
RobKeay
Having spent the last 4 days towing with a 2.2 I do prefer it. Having driven land rovers for years my driving style has had to change. The only thing I don't like is the extra fuel it's using. Feel if you had stuck to another brand the figures would be in the 30's. But I'd rather pay for more fuel than go down the other routes also they wouldn't tow my trailer. It's a 3.5ton tipper.
We had a drag race at the yard the other day between the 2.2 90 xs and a 2.4 xtech. There was nothing in it. Also in the race was a 300 tdi which we left for dead.
Post #147090 25th May 2012 7:10pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
to be honest though, even if, say a hilux could pull more than the 2.2tonne limit it has it was use more fuel with the extra 1.3tonnes weight diff.
i had a 2000 reg 2.5litter nissan navara before my 2.4 puma and that did about 10mpg with 2 tonne behind it!!!
thats interesting about the speed diff, guessing you didnt race past 82mph Wink
would you say your 2.2 is more quiet compared to the 2.4?
Post #147095 25th May 2012 8:29pm
RobKeay
The drag race was in a field so was not that fast.
I would not know about the 90 mph speed limiter as the uk limit is 70. I would guess that if someone did do above 82 it could explain a drop in mpg.
It's loads more quiet, it has three layers of sound proofing on the bulkhead. My 2.4 had noise killer fitted and the 2.2 is still quieter, can't wait to fit noise killer as well.
I wouldn't change for the sake of it from 2.4 but if it's time for you to change I wouldn't have second thought.
Post #147099 25th May 2012 9:09pm
chadjizz
RobKeay whats noise killer?
im changing to a 130 as the hi cap single cab is not big enough any more. plus i do like the idea of a quieter and a little bit more refined drive....!
iv put a deposit down on a new one, second hand 130's are just far too much.
Post #147102 25th May 2012 9:20pm
RobKeay
Its a brand of sound proofing. It's simple stuff just stick the pre cut pieces on and away you go. Doesn't make a massive diffence but certainly knocks the edge of the noise.
Post #147121 25th May 2012 11:09pm
ZeDefender
Bear in mind that some on this forum have had power-loss problems in really hot weather. I love my Noisekiller but it really heat-insulates the engine block and once I removed mine the power came back (okay - so it was 30+ degrees outside). I don't think the 2.2 noise insulation has any heat-insulation effect. Tell someone you love them today because life is short.
Post #147133 26th May 2012 6:53am
Grockle
dgardel wrote:
NinetyTD4 wrote:
Brian, I goes you should not buy from a dealer like that. Stating there were no DPF issues on the PGA engine fitted into Freelanders is close to a big lie - just browse around and see what that had on that one. I was in England last week and had the opportunity to drive a 90 /w 2.2 l engine and yes, it is indeed the modified Ford engine, not the less durable PGA.
From direct comparison to my 6 week old 90 (2.4) I can tell, yes it is substantially quieter. The 2.2 l engine feels more sportive then the 2.4, but I don't like the new engine as it drives my driving mood more towards speeding. I am happy I got one of the last 2.4s ...
Is the engine cover that do the difference......
Hi DG,
Does the 2.2 engine cover fit straight on to the 2.4 without modifying etc.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #147148 26th May 2012 8:53am
JSG
Grockle wrote:
Hi DG,
That is the six million dollar question we are are waiting to find the answer to Thumbs Up John
2011 Tdci 110 CSW XS
Post #147166 26th May 2012 12:54pm
rover
butter
Post #147208 26th May 2012 9:17pm
rover wrote:
.... The short 1st gear in the 2.2 is anoying, I dont know whether to try starting in second instead. ....
But the short first gear is one of the things that makes it work so well in many of the 'working' applications!
It simply reinforces the old adage that you can't please everyone all the time; for me, as one who often operates at GTW that low first is a godsend (also ideal for creeping along in traffic jams on tickover) and makes the TDCi much more usable than the tradition higher first and the need to do a low-to-high transfer shift on the move.
Pulling away in 2nd is fine and I do it a lot if unladen, unless it is uphill. Just let the clutch in on tickover letting the anti-stall take care of the engine, then accelerate. If pulling away in 1st, again let the antistall take care of things until you're rolling and go for 2nd almost immediately.
Post #147488 29th May 2012 9:37am
22900013A
I agree with the sentiment that the 6 speed box is very similar to an HGV gearbox. Most lorries I driver are very low geared in 1st and 2nd, then get higher as you go 3, 4, 5, with 6 being pretty much just for speeds over 50 mph. Usual 56mph cruising revs is about 1800-1900 rpm so very close to the Pumas 2000rpm at 60mph.
I always use 1st gear to pull away from rest in my 110, and so far have had no clutch issues after 33,000+ miles. I wonder how well the clutches will fare with folks pulling away in 2nd? Many lorries have stickers in the cabs warning against doing just that as it shortens the clutch life. Then again, with six gears rather than 5 would the increased number of gearchanges decrease the clutch lifespan?
Post #147496 29th May 2012 10:58am
I don't really see why pulling away in second (under "low stress" conditions anyway) should do the clutch any harm on a Puma, since there is no need for any significant slipping. Whenever I pull away from rest in any vehicle I always (and have always) kept the revs as low as feasible, and then accelerate one the clutch is fully in (HGV style). I have removed clutches from vehicles where I have done well over 100k miles and there has been insignificant wear on the driven plate as a result. I also always double-declutch down changes (and quite often up changes) so there is really very little wear or clutch stress.
The anti-stall on the Puma actually means that you can be extremely gentle with the clutch when pulling away, which I believe to be sound practice since the clutch - even in the latest versions- is not famous for its robustness.
My Puma had a new clutch a c.50k miles since, being a 2007 model, it originally had the one with springs made of cheese (and 50k miles wasn't bad going); since then it has done another 48k miles with no clutch problems despite regular 2nd gear starts.
If towing, heavily laden or pulling away uphill I will always use first.
Post #147506 29th May 2012 11:47am
chadjizz
talking of the clutch.....have they fixed the problem in the new 2.2 ? do they last longer...?
Post #147605 29th May 2012 9:30pm
spudfan
Ireland
Has it been out long enough to find out Laughing
Seriously though the replacement clutch in my 2008 is going fine and no problems as yet with my 2011 2.4 model. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #147610 29th May 2012 9:40pm
Page 4 of 4 <1234
