Home > Maintenance & Modifications > Shelf Up In The Roof!
Page 2 of 3 <123>
ZeDefender
Amazing how cheap sheet aluminium is (see eBay...)
I'm getting a bit obsessed with it - go-karts, tables, skate ramps, even shelves too Thumbs Up
Zag - can't you use the bottom half of that dog guard? Laughing Tell someone you love them today because life is short.
Post #146720 23rd May 2012 7:17pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
I made one for my 90. Used 3mm ply rested on the top of my window guards, but with a little playing it could have gone from the roof seam. Used a bit of angle along the front for rigidity and attached it to the dog guard at the back.
Even got some nets from MSS for underneath.
Best photo I can find at the moment
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2002 Defender 110 DC
Post #146725 23rd May 2012 7:27pm
Zagato
Thanks will look up ali sheets and looks the ticket Ben Thumbs Up
Post #146727 23rd May 2012 7:34pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
I liked the look of the unit in the back of Ian Woolley's (Mudrut) Utility - he bought the truck with it on apparently but this is what he advised
Ok, I did quite a bit of detective work on this one for you. It turned out that the roof shelf thingy was made by Trek Overland. I have just spoken to Claire at Trek and she confirmed that it was a prototype. However, they are in the process of producing some more in quantity. She suggested that you email her (info@trekoverland.com) and she will let you know when they have a batch ready.
I haven't followed up on this so far....but if anyone wants to do so then fill your boots
My other option/thought is to use some redundant bed slats which come already slightly curved, made of ply and with a spacing webbing, that I just happen to have lying around
Post #146741 23rd May 2012 8:06pm
leeds
The best roof level shelf/cage I have seen is the one in our red 110 (OK you could say I am biased! Razz )
With front flap down.
With flap up
Brendan
Post #146745 23rd May 2012 8:16pm
landy andy
Mine
Post #146772 23rd May 2012 9:39pm
TACK
Zagato wrote:
That's more like it Tack, just the job, in fact I like all your mods Very Happy
Agreed mesh isn't so good, a solid shelve is much better. I have to work around the interior window trim and make some brackets up to fix onto the roof fixing bolts. Is yours a sheet of Ali turned up at the ends, did you need anymore strengthening in the middle, was it about 3MM you used????? Laughing
Also how did you attach the awning rail to your Thule bars (like it Wink )
Also where did you get the mesh from to make your seat box cages and shelf?
Sorry about all the questions Embarassed
Thanks Zag, it's flat Ali, 2mm, with ali 90 degree angle at the front and back which strengthens the shelf, the bolts as you can see from my gallery go through the angle.
I fabricated some plates to fit the rail to the Thule bars and simply Bolted the plates to he Thule rail Thumbs Up
Got the mesh from http://www.fhbrundle.com/perf-04.htm
Thumbs Up
Post #146777 23rd May 2012 10:23pm
TACK
Pic's not brilliant, but gives you an idea Thumbs Up
Post #146780 23rd May 2012 10:48pm
there is another on the market called "space rack" - boab
http://www.boab.biz/acatalog/info_189.html
Post #146804 24th May 2012 7:23am
landy andy
That is what my one started as.
I got it from boab, but was disappointed with the materials and build. So rebuilt it with Ali flat plate, instead of wood slates that they couldn't be bothered the fix properly, and also added another couple of cross members to stop items falling down. Am now very happy with it.
Andy
Post #146806 24th May 2012 7:50am
ZeDefender
The boab one looks like an Ikea slatted bed frame/base (but worse quality)Shocked
It's given me an idea 'cos I've just been cleaning out the garage and I've got one in there... Thumbs Up Tell someone you love them today because life is short.
Post #146811 24th May 2012 8:19am
BigRuss
That's what Ian woolly has in the back of his. Russell
2011MY 110 XS USW Black
Post #146814 24th May 2012 8:26am
yeah, the boab one shows you exactly how it's made and could be used as a starting point for a design.
Post #146862 24th May 2012 12:49pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Andy i am very surprised that you were disappointed with the quality of the rack. FYI i actually cut and bent the materials to be fully assembled and welded up by my old boss who sells them to chris @ boab (No plug intended or implied)
I know when they were designed and built, i suggested to use 1inch weld mesh instead of the wood but chris at boab said the wood would do as it was for light items. 2004 TD5 Defender 90 xs station wagon
Post #146919 24th May 2012 8:03pm
landy andy
Hi johnszs,
I was disappointed that it was wood, and that it was only partially fixed. So your bit was loverly.
Can't understand why wood would better than Ali. So I agree with you
Andy
Post #146921 24th May 2012 8:29pm
Page 2 of 3 <123>
