![]() | Home > Puma (Tdci) > Rough ride |
| Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306
How can I go about making my 90 ride a little smoother? It's like a bouncy sj on leaf springs!!! 90 Puma HT
I would think mine are standard springs and shock, not completely sure of tyre pressures but will adjust them tomo 90 Puma HT
| Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251
Depending on tyre brand but just lowering your pressure makes one heck of a difference!
I have BFG Muds on and if they are at 2.5 bar (somewhere close to 38PSI) it is as choppy as hell. If i lower the pressure to 1.9 bar it feels like I drive a Rolls..... and tyre wear is nice and even. |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2671
Agree dropping tyre pressures improves the ride.
But it's negative on MPG...Run much less than 30psi. and the MPG reduces, as does cornering! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Rear were at 48 and front were 35 ish!! Seems better! Cheers mrs might be a bit happier!! And my back!
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Any suggestions for pressures on a 110SW? Tyres are 265s.
35/45 sound okay? Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353
Run our 90xs with 28/34 unladen, plus had bilsteins fitted all round. Makes a significant improvement. Ultimately will have to change the rear springs to a lower rating as it runs unladen most of the time.
Stu |
I run 30 psi on Front, and 40 psi in rear... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Mainly on-road? What's the MPG like? Thanks. Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
