Home > Puma (Tdci) > Softening the Ride on my 110 USW
Page 2 of 2 <12
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Martin, perhaps siting your Mrs over the rear axle will help Whistle she'll also be far enough back hopefully for you not to hear her 'going on' - you can then relax and enjoy your journey
hth
Dan 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #146291 21st May 2012 6:29pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Is it RKB500300 white green Coil spring?
Hey guys,
Last week i bought pair of rear springs for my 110 SW puma from ebay uk and i am yet to receive them. It says white green green but could anybody confirm that they are RKB500300 please?
http://www.ebay.co.uk/itm/231034096874?ssP...1423.l2649
Many thanks.
Regards,
Diluk
Post #272712 10th Oct 2013 3:34am
MartinK
Well, RKB500300 is indeed White/Green/Green. If you already have a standard SW, then these should be the same as fitted... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #272716 10th Oct 2013 6:32am
dilukabey
Thanks for the post MartinK. Well when i checked my currently fitted rear ones, it was purple brown (Same for crew cab and utility 110 i guess). So hope my green and white ones will give me a better ride? Cheers! Smile
Post #272741 10th Oct 2013 10:55am
MartinK
Aha - ok I thought you has a SW (as per your avatar)
I did the same as you. The new ones are slightly longer, but do weem to offer a slightly better ride. However the vehicle will be even more jacked-up at the back unladen because of the slightly longer springs - see comparison here:
I haven't adjusted my headlamps' dip beam yet, but that's now set a bit low because of the higher rear end.
One day I'll buy some -1" springs to put the ride height back, and make the rear end a bit less "jacked-up".
The Koni shocks combined with the new springs was a vast improvement Smile Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #272742 10th Oct 2013 11:08am
dilukabey
Hello martinK, I do not mind the raised back. I hope it will have some more ground clearance also. Have you actually gone through my ebay link. Please check. Appreciate if you could confirm that they are RKB500300. Many Thanks.
regards,
Diluk
Post #272744 10th Oct 2013 11:26am
dilukabey
Yesterday i change my rear 110 brown purple to white green green coil springs and i noticed much better ride. Did not really notice any raised back.
Regards,
Diluk
Post #283766 20th Nov 2013 5:49pm
MartinK
Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #283772 20th Nov 2013 6:01pm
Page 2 of 2 <12
