Home > Maintenance & Modifications > Fitting 3mm Chequer Plate Sill Guards
affiliate13
2012 Defender 90 Puma 2.2 HT Sumatra Black
Hi all,
We pick up our new D90HTs tomorrow and plan to bolt on some side runners, steering guards and side sills.
The runners and steering guards should be easy enough but since i am having to drill holes to fit the sill guards i thought i should check if there is anything i should or should not be doing before i start?
I got the bolts and some spring nuts, but i wondered do i need anything else?
Cheers.
Post #145561 17th May 2012 5:11pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I always use a sealant between the cp and the bodywork to prevent any crud being sandwiched between the two. Once drilled treat the holes with touch-up and then wax the back of th cills.
Post #145600 17th May 2012 8:19pm
SGH
I got 3mm for my 130 and when fitted could not open the doors as gap too tight Big Cry 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #145601 17th May 2012 8:19pm
bob neville
Had the exact same problem with the genuine LR sills, Yeovil LR sorted it for me Thumbs Up
2013 Defender 90 CSW - sold
Post #145606 17th May 2012 8:35pm
Killer90
Site Sponsor
yep make sure you paint the holes you have drilled because over time the steel with react with the ali causing bubbles Crying or Very sad counter sunk screws look much better than rivets imo try and get stainless ones Thumbs Up
Post #145609 17th May 2012 8:39pm
affiliate13
I got these:
http://www.ebay.co.uk/itm/Land-Rover-Defen...439ea5b8f9
But for the 90.
They are countersunk which is nice, and the paint job on them seemed well finished.
Ginjez,
What sealant do you recommend? i can get some tomorrow afternoon.
Bob,
What did Yeoville do to sort that please?
Killer,
Yes, i think the bolts we have are stainless and black.
I will look into getting some paint/touch up to treat the holes, maybe Halfords will have something.
Thanks for the replies all, appreciated. Smile
Post #145620 17th May 2012 9:13pm
bob neville
Adjusted the sills at the back. There is some play in the brackets that hold the sills and they adjusted these so the back doors would close. Pain of a job, I removed the sills to replace the rotten seal between the sill and the body and then spent a few hours trying to get the clearance to shut the doors.
Post #145625 17th May 2012 9:26pm
affiliate13
Hopefully it will all be OK, i bought some new tools for the occasion. lol.
Post #145628 17th May 2012 9:32pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
I've never understood sill guards - you drill holes into something you're trying to protect, which themselves are only held on by a few bolts. Why not just take them off and put something better on? You can then replace the undamaged item when you want to sell it? Just my thoughts... I'll get my coat. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #145657 17th May 2012 11:03pm
affiliate13
Thanks Mr Flips,
I take your point, but i have them bought now and i think they will do the job well enough though.
I am thinking i might line the inside of the guards with a strip of this in each:
http://www.ebay.co.uk/itm/NEOPRENE-RUBBER-...814wt_1039
I got some extra nylon washers to keep the nuts off the sills and some black silicone to keep the bolts off the new holes too.
If i get it done this weekend ill post some pics, steering guards and side steps first though i think, as it is rain forecast for tomorrow. Sad
Post #145862 18th May 2012 10:34pm
Nick-St
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Reviving an old thread... Just gone to fit some and they won't fit under the doors either!
How much adjustment is there in the sill? The gap under the front passenger door is about twice as big at the front as it is at the back! The plate only fits under the drivers door - all the others would rub...
Post #263175 2nd Sep 2013 6:34pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
Don't bother trying to adjust the sills, adjust the doors to give a uniform gap along the sill/door gap and the 3mm will fit a treat.
Plenty of paint and then wax oil on the driiled holes to prevent the good old electrolytic action between the steel and aluminium.
The jobs a good un. Thumbs Up You only have one life, live it....forget the cost.
90XS Hardtop
Post #263185 2nd Sep 2013 7:08pm
Nick-St
Sonarmender wrote:
...adjust the doors...
Is that just a case of slackening the door hinges, packing under the door & then tightening everything up, or is there more too it than that?
Post #263187 2nd Sep 2013 7:20pm
Happyoldgit
^^Pretty much although you may have to adjust the lock striker afterwards. Steve.
http://forums.lr4x4.com
Post #263197 2nd Sep 2013 8:21pm
BigWheels
Thumbs Up Rock sliders with or without tree bars are proper protection. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #263283 2nd Sep 2013 11:54pm
