Home > Maintenance & Modifications > water in my tank by mistake
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
I forgot to replace my fuel cap after filling with diesel, then went to the car wash...
I know... i know...
So now what? Do i just keep a close eye on the water trap? Or must i do something else?
Thanks www.ralton.co.za
Post #144722 13th May 2012 12:07pm
Personally I would get the tank drained out if I was you that way at least no more damage can be done. Then re fill with fresh.
Post #144725 13th May 2012 12:30pm
Laurie
Detergent in the fuel could be lethal.
Post #144726 13th May 2012 12:32pm
muppet !
Post #144754 13th May 2012 4:57pm
AndrewS
Drain the fuel filter for the next few days into a clear container, this way you will see if water is in the fuel. eventually you will get rid of the water. 130's have feeling's as well you know Smile
Post #144757 13th May 2012 5:00pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
As Andrew says Cool
If water is present, it will sit in the bottom of the fuel filter [being 'heavier' than diesel] as and if is drawn up.
Keep a close eye on it for a week or so Guns and Landrovers .... anything else is irrelevant.
Post #144811 13th May 2012 9:36pm
ickle
What about adding meths to the tank as water is absorbed into the meths which will pass through the system (remember reading something about water contamination on a RAC rally years ago and all the local Welsh towns selling out of meths) - or is that only for a petrol engine?
Keith
Post #144815 13th May 2012 9:46pm
Tim_NZ
Australia
I would drain the tank, flush, and refil. The cost of the diesel to do this will be minor compared with replacing the fuel injectors, pump, etc. The fuel filter water trap is only capable of stopping a very small amount of water.
Post #144833 14th May 2012 1:31am
Zagato
Wonder if you could use something like a Delphi 296 filter on Land Rovers which removes dirt and separates water. They are used on boats so would need something to cope with a bigger flow rate...
Post #144836 14th May 2012 7:43am
Naks
Yep, don't take any chances.
Also try to flush the fuel lines with clean diesel. --
Post #144844 14th May 2012 8:55am
I would be less worried about the water that the other crap that will have got it, from dirt particulates to detergent. I think you would be foolish not to drain the tank completely and change the filter, and after refilling with clean fuel and running for a week or so I would change the filter again.
A tank of fuel and a couple of filters will cost much less than a new engine.
Post #144884 14th May 2012 11:35am
