![]() | Home > Maintenance & Modifications > Puma bonnet on early Defender |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
the grp bonnets are a pain to fit you have to adjust the slam panel to make them fit and shut nicely so do that first before having the bonnet sprayed
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Thanks for the info
![]() I picked up a brand new Genuine parts bonnet on eBay for £150 so hopefully no fitting problems and cheaper than a fiberglass bonnet. 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
that is cheap good luck
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21021 ![]() ![]() |
That's what I thought. But they can't all be bad can they. (I hope!) |
at £150 i wouldnt complain
Brand new unpainted still with LR parts label on it...So I guess not stolen
![]() Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Depending which header tank you have fitted to your Defender, you may need to space the header tank away from the wing slightly....
300Tdi (for example) with the large plastic header tank - you will need to space the header tank away from the wing by about 1" to stop the header tank fouling the inside of the bonnet. A 1989 Land Rover will probably still have the lower, smaller black metal header tank, and you might get away without modifying anything. Ian |
