![]() | Home > Puma (Tdci) > so are they sorted now? |
BigGeorge Member Since: 08 Aug 2009 Location: Zurich Posts: 43 ![]() ![]() ![]() |
I have apprently I new vacuum pump (it was changed on my request for free). I didn't take such a close look at the old but the new one looked new (obviously). As far as I know only the seal was improved, which I guess is not diretly visible.
in any case... insist on the free of charge replacement. The bulletin is clear in the wording. Some LR dealers always try to screw their customers. Same goes for the clutch.. though there I think it's only replaced once it creates problems. has a different part nr. apparently. Again cannot look into it. See bulletin Subject/Concern: Brake Vacuum Pump Seal Oil Leak Models: Defender (LD) 2.4L Diesel Only 2.4L Diesel Only VIN-range: 7A732615 Onwards Markets: All Section: 206-07 Summary: Oil leaking from the brake vacuum pump front oil seal. Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31. Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07 (70.15.19)). Parts Required: Description Part Number Quantity Brake vacuum pump LR012183 1 Gasket LR004381 1 The goons are trying to bring me down! Defender 110 SW MY10 useless piece of ![]() Defender 90 V8 50th Anniversary Series IIa 109 / 6 cyl. ex-fire truck |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
Requested mine to be replaced as a precautionary measure. Dealer agreed when pointed to posting on GTR. Serial number on the vacuum pump body ends in 'XP' for the latest modification.
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Still cannot convince my dear dealer to change it I have the oldest model
![]() ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
GR110P Member Since: 16 Aug 2009 Location: GR Posts: 15 ![]() ![]() |
thank you very much.
I ll try to convince mine tomorrow... I mean ,I found the relative TSBs,as it concerns the brake vacuum pump,I think it is stated clearly "in case a customer raise concern,put a new one..." For the clutch it mentioned "should it become necessary......" So ,I guess they should replace the brake vacuum pump for free. We ll see... |
ok with the brake vacuum pump.
![]() No with the clutch assembly. So I m going to pay to have the stock clutch assembly replaced with the improved one. At least I ll know that those two serious issues are ok . Thanks George ![]() Cannonball thanks for the info about the pump,I ll check it. |
So ,there's no way we can check if the pump or clutch is indeed replaced .....
I mean,if we consider the worst scenario,they can always install the same one,or even noone.... any other ideas ? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8372 ![]() ![]() ![]() |
well my 09MY still suffers from diff problems, has the uprated sump, bottle jack and all the mods upto that point though.
Stoneaway Grey gets my vote Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Yours is a 110 or 90 ? I heard that 90 s have one pin diff-carriers while 110s have 2 pin diffs-carriers.
My dealer said that the 110 I m going to get has 2 pin diff-carriers in both F-R diffs. |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Just ask for your old clutch parts and if emergency you can re-install Puma 110 - gone Series III 1973 - going strong |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
Warranty claims you cant request your parts back, If they wont replace your pump - spray some oil around the engine bay and say its failing ![]() |
Humm,
At least in Chile if it is a warranty claim, the piece should be keep by the dealers to be showed to LR inspectors. (you know, 3rd world country) Anyway, when they changed the clutch they invite me to see the new clucth already in position and the old one. Regarding the pump is quite easy to see if it is one of the new model or not. I remember that we have some thread with this information here. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
I was refering to the clutch that he was paying himself to have changed - then no longer a warenty item. Puma 110 - gone
Yes,I was told that the old clutch is mine,I can take it with me.The pump,no it goes back to LR.
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
Hi. L/R diffs are 2-pin carriers and 4-pin carrier for heavy duty diffs for some 110's and all 130's. Cheers Puma 110 SW 90 V8 SOFT TOP |
