Home > Expedition & Overland > Roof tents
Page 4 of 9 <123456789>
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
The front edge was very shallow due to the pivot so your feet could only be flat, and the rear the canvas slopes in so was always touching my head Thumbs Up
Post #60294 21st Feb 2011 12:59am
leeds
BigMike wrote:
Boab will fit it without charge.
4x4 Overlander will normally fit them for forum members without charge.
Please note that that dependent on the roof rack and the particular roof tent depends on possible location of the tent.
Also dependent on the roof bars depends on whether the clamps have to be modified. I am thinking in particular off the Thule aero bars which are low profile but wide.
HTH
Brendan
Post #60308 21st Feb 2011 8:34am
BigMike
You've lost mw. Pivot? Are we not talking about a maggi? That's why I asked re the XL. The walls are vertical..
Brendan, your other post saud fitting usually 75 quid I think, hence my point re free fitting from boab. They're pretty easy to fit though let's face it
Post #60318 21st Feb 2011 10:06am
leeds
Hi Mike,
I think you will find that both Nene Overland and Boab normally charge £75 + VAT for fitting. I was trying to give people a general idea on costs. Actual final deals will vary on case by case basis
Whereas on some roof tents/roof bars/roof racks the fitting can be straight forward on others not so straight forward.
Reaching the fittings under a Patriot roof rack at the back of a Defender can be awkward unless you have thin forearms. I find it easier in that situation to hoist the back of the Patriot roof rack away from the roof.
Will be fitting a Patriot rack and roof tent to a Disco 2 shortly. Will mount the roof tent onto the rack first then lift the whole lot up together.. On a Patriot type rack you have to use a spacer on the U bolt or spot weld a coach bolt on. Aero bars might involve drilling out brackets and then welding on new coach bolts. Autohome roof brackets have good galv on which needs removing before welding.
Using an electric hoist makes life easier especially doing it single handed.
Yes they can at times be straightforward on other combinations not so straight forward.
One of the problems with fora is that at times I do not always express what I mean clearly, if so I apologies for that.
Anyway off to NEC shortly. Will see how much interest there is in Autohome/maggiolina roof tents. Should be an interesting week
Brendan
Post #60322 21st Feb 2011 10:38am
Sonic3d
Post #60330 21st Feb 2011 11:04am
BigMike
Ah ok
Post #60331 21st Feb 2011 11:05am
Stoo
2005 Defender 90 Td5 XS CSW Bonatti Grey
Anyone have any experience of either of these tents?
http://www.safari-equip.co.uk/index.php?page=200
http://www.terrainvehicles.co.uk/hl/Extended%20tent.html
Be good to get any first hand experiences?
Stoo
Post #61165 26th Feb 2011 9:57am
leeds
Hi Stoo,
First I have no personal experience of either tent but will make a couple of comments
Safari Equip states
Quote:
Constructed from 600 denier canvas/nylon
What do they actually mean by that?
Canvas used to be cotton, now considered to be mixed cotton/polyester say 30/70
Terrain vehicles
Quote:
Material
Fly sheet: 200D oxford with PU coating.
Tent -: 300D polyester with PVC coating.
D I assume to be denier which is a fibre measurement
Waterproofs used to be made from PU coated nylon. PU could/used to delaminate from base fabris particularly in high crease areas
I used to make rope tackle bags for caving out of polyester coated with PVC. Think the polyester used to be 800-1000 denier. Very strong certainly not breathable.
I would certainly suggest you question the breathability of these fabrics
Brendan
Post #61167 26th Feb 2011 10:20am
T1G UP
landy andy wrote:
Mine
Andy
nice Andy. what set up is that?
Is that a changing room or a tent?
Fits well on a 90 :thumbsup:
Post #61171 26th Feb 2011 10:51am
landy andy
It is a side awning, and changing room. You can also attach an extra set of guy lines and drive away from it.
It is good as it allows you to get in and out of the tent without getting wet,
Also have a rear awning that I made.
Andy
Post #61195 26th Feb 2011 6:40pm
Stoo
Brendan - thanks for the responses - good points - I have no intention of buying a roof tent without seeing them in real life.
What do we reckon is the best one out there - want a fold-out 1.4m canvas style (not a clamshell), with a section that covers the ladder/back of the truck.
Hannibal? Howling Moon? Ezi-Awn?
Thoughts?
Stoo
Mr. Green Mr. Green
Post #61503 28th Feb 2011 9:11pm
BigRuss
Thoughts?
Stoo
Mr. Green Mr. Green
I'm in the same boat as you there. What I can tell after much time spent looking between hannibal and howling moon is that on the hannibal the bit that covers the back of the vehicle has a door at the side and then the back can be opened up, where as the howling moon only has a door at the back.
Another thing I found is they both have built in ground sheets.
Russell Russell
2011MY 110 XS USW Black
Post #61510 28th Feb 2011 9:22pm
leeds
Big Russ and Stoo, the pair of you had better go and sit in the naughty boys corner!
What is wrong with the original and best roof tents maker? AUTOHOMES Have a look at the Overzone, Overcamp and Overland at the bottom of the page HERE
If you want a paper version drop me a pm with your address
Brendan
Post #61536 28th Feb 2011 10:17pm
xatzhs
Glynparry25 wrote:
Russ,
I know a few people who have used this company http://www.rooftentslimited.co.uk/.
Not the best of website, but have heard the tents are awesome quality.
Glyn Dog Sheep
So I know this is massively digging into the past, but I've been good and persevered with my Search until I dug something up! Very Happy
Anyway, I've got a mate looking into these, has anyone else heard anything about them?
Post #144424 10th May 2012 9:52pm
JWL
I don't know whether I should post this Whistle this is my Cheapskate Version Laughing
Post #144432 10th May 2012 10:29pm
