![]() | Home > My Defender > Mine now - 2003 TD5 90 HT |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038 ![]() ![]() |
There's always something to do on a Land Rover, so I now have a revised list of things to do over the summer, time permitting:
1. Finish rear floor soundproofing and replace matting 2. Replace duff single tone horn with a twin horn setup 3. Buy and fit a powered sub speaker to add some depth to the Alpine unit 4. Drain and re-fill all fluids in gearbox, transfer box and diffs (for peace of mind) 5. Paint and waxoyl chassis and doors/bulkhead etc 6. Get an auto electrician to connect the heated seats up 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Haha! I'm famous now
![]() http://www.lasalle-trim.co.uk/customergallery http://www.lasalle-trim.co.uk/comments/reviews 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
Could you not wire up your own heated seats? Or is it more complicated than I'm thinking it is?
v40mav Member Since: 25 Aug 2008 Location: UK Posts: 206 ![]() ![]() |
Well done - great PR
![]() Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
Probably, yes, but I want to make sure it's done properly, so may bone up on that, it can't be too hard. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol Last edited by RRUK on 21st Aug 2014 8:41am. Edited 1 time in total |
Today I finished off the sound proofing in the rear tub. Thoroughly cleaned off the floor using some solvent cleaner, and then cut a sheet of the alu' backed foam sound deadening material to size. It's perfect for this as it's 10mm thick, made of closed cell foam so won't absorb moisture or water and is heavy, so it really deadens the panel vibrations.
Once fitted I found the tailor made Land Rover rear rubber mat didn't quite fit, obviously, as the inner dimensions of the tub have been reduced by 20mm. So, I just sliced it up, 2 sections for the wheel boxes and then the floor section. Once fitted, they are still nice and snug and there's no ripples. Re glued the rear lower door seal, rubbed down the galv door strip to brighten it up and used new screws to fix it down. Just been out for a test drive and it has made an excellent difference to the noise reduction. Before, the exhaust noise would boom from under the rear floor, now it doesn't. Now that the entire rear of the Landy and the roof panels have been covered in this stuff, it has made the driving experience much nicer. Eventually I will also soundproof the seat box, floor, tunnel and bulkhead. I'm also toying with the idea of covering the rear of the bulkhead in some sort of fabric, as well as the curved side panels above the wheel boxes, just not sure what material yet. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Good man!
Nice to hear its all coming together. Heated seats - once fitted (yes get a proper bloke to do it ![]() Don't know why you didn't get a rangerover to start with (oh yes you did ![]() Should be good when its all done, but don't make it too nice so you don't want to get it dirty! DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
You could always fit the Noisekiller front kit and their engine blanket. Well worth it
Is the engine blanket any good? With the engine having the acoustic cover, my bonnet already soundproofed, I wonder what value it will add?
The interior stuff from Wright Offroad looks the best stuff, I think its the same as the Exmoor moulded version too, but very pricey! 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
Makes a fair difference I think. Pricey though, so it depends on how much you value your comfort. It's never going to be a FFRR.... it does make the engine quieter at speed, but this tends to mean you can hear the gears/tyres howling instead
in the Puma you can cruise at 70+ and not hear the engine, the BFGs are quiet, i only hear wind noise. not even that when i am on my own and the music is on. no transmission noise either.
i have the NK bonnet kit which i will fit when it gets dryer and warmer ![]() |
JOSNOS Member Since: 06 Apr 2012 Location: Bucks Posts: 154 ![]() ![]() ![]() |
Beautiful Landy and what a good job you have done.
WelshDefender Member Since: 02 Dec 2011 Location: Gwent Posts: 62 ![]() ![]() |
Landy is looking cracking mate. Is that the Flatdog bumper and A bar you have fitted?? If so, how is the quality on them as I am just about to place an order for bumper and A Bar.
Cheers |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
[quote="RRUK"]
Probably, yes, but I'd rather get it done properly[/quote its very very easy, i did it to my gf fiesta zetec s, brought them from a memeber on here, SGH (mps trading) |
