Home > Puma (Tdci) > Underbody protection
Coko
2008 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Can you please recommend which diff guard (front and rear) and tank guard shall I go for?
I have been quoted various sums ranging from £12 up to £120 per guard and not really sure which one to go for. :roll:
Recommendations please...
Thank you :thumbsup:
Post #14403 19th Aug 2009 7:44am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I use QT diff guards and can highly recommend them Thumbs Up don`t waste your money on the type that clamp to the diff pan as they fall off when hit Thumbs Up
Post #14404 19th Aug 2009 9:11am
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Do not forget the fuel cooler guard and handbrake guard also
Post #14405 19th Aug 2009 9:16am
Coko
Thank you chaps. And what would you recommend on the tank guard?
Post #14406 19th Aug 2009 10:02am
Sonic3d
I don`t have a tank guard Thumbs Up the tank is tucked up out of the way unless you start using your Landy as a challenge truck Thumbs Up
Post #14407 19th Aug 2009 10:14am
Glynparry25
I have fitted
Mantec Steering guard (£140)
Southdown Front axle guard (£150)
D44 Fuel cooler guard (£30)
D44 Transter box/ handbrake guard (£50)
Mantec tank guard (£120) (Fits with NAS rear step)- I would have liked to have gone for the southdown item.
I will be fitting a Qt rear axle guard when funds premit.
Glyn
Post #14408 19th Aug 2009 10:17am
Coko
Thank you chaps... :thumbsup:
So I asume that there is no point of spending £200 on two equipe wraps when I can have it for £80 from qt, is there? :roll:
Post #14410 19th Aug 2009 11:57am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Most important guards are steering (that'll be the bit you break first) and front diff.
Diff
QT guards are great - they allow you to properly isolate the diff but they'll reduce ground clearance by an inch or so. They're also quite a lot of money. A bolt-on diff pan guard for the front can be picked up for under £20. Admittedly not as secure as the QT ones but better than nothing.
You won't get a pan-covering one for the rear of a puma so you'll need to buy a QT guard if you want one there (not as key as the front because chances are you'll have punched your front one out before you hit the back (unless you're rock crawling).
Steering
Main choices are:
Steel or Aluminium
With holes in it or without
For a winch bumper or not
With integrated recovery eyes or not.
My guard was from Paddocks IIRC at around £90. I went with Aluminium (around £10 more but lighter - maybe) with built in recovery eyes for a non-winch setup. Some of them are modular to allow you to fit to winch bumpers at a later date. Holes vs no holes is personal choice. Some say holes allow mud to pass back through and prevent it becoming a plough in a rear recovery. Some say mud never passes through anyway but at least they can use a solid guard as a skid and not a cheese-grater when going over lumps. Mine has holes, which encourages my son to post stones through.
Some people will also recommend dan bars or something similar as an alternative to a big guard. I've no experience of those but I'm sure they're also pretty strong.
Others
Personal choice and a decision around cost and weight. They're not light so you could easily add 100kg of permanent weight by going whole hog. Ironically you'll need the guards more as you sink further into the mud Razz Depends what you use it for really. I'd love to think that mine was protected from field mice firing small arms but I'm unlikely to really need it. For greenlanes you'll be pretty well covered with steering and diff guards. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #14413 19th Aug 2009 1:07pm
BigGeorge
Switzerland 2010 Defender 110 Puma 2.4 SW Keswick Green
it always depends on the intended usage.
On the Defender 110 I have steering guard and that's about it. A fuel cooler guard is something to consider especially when driving in the woods/forests. I guess the engneers brain were turned off when choosing the location Wink
On my Jeep I have a big sort of pan protecting transmission and engine/oil sump.
It certainly helps when doing serious offroading (use it for fun competition) but it also attracts all sorts of dirt and stones / pebbles. When pebbles are stuck between transmission box and guard you get nice vibrations. The other day I was cleaning the underbody and found a big piece of "rock" about 10 inch by 5inch by 5inch sitting on the guard. Don't want to know what would have happend to the one driving behind me when doing 60mph if it fell off the guard.
and as mentioned before... wheight is always an issue. (That's probably the main reason for D3 getting stuck when we still manage the incline, even though they have the smartest electronics built in)
George The goons are trying to bring me down!
Defender 110 SW MY10 useless piece of Censored ... but I like her
Defender 90 V8 50th Anniversary
Series IIa 109 / 6 cyl. ex-fire truck
Post #14415 19th Aug 2009 2:04pm
Glynparry25
After previous experience both through fun and work I have gone out of my way to protect all vunerable parts of the 110, and that is why I have gone all out. If I were to either do all my time on the road or just green lanes yes a steering guard and axle guards would be ok....BUT if you want to do a little more or long distance why take the chance?
As for cost and weight- compared to the price of what the guard protects it is pennies, and 100Kg on a 2 ton car is nothing. You could save more weight by removing all the items you don't need in the car.
Glyn
**I fitted the transmission guard after the day out in Sailbury plain. When cleaning the car after I found huge amounts of mud and grit jammed between the transfer box and the hand brake- if it was a rock rather than mud it could have easily spoilt my whole day.
Post #14416 19th Aug 2009 2:15pm
alantd
Glynparry25 wrote:
... and 100Kg on a 2 ton car is nothing...
100kg is around 15% of the total load-carrying capacity of a standard 110. That's quite significant. Admittedly it is low down but you still don't want to add unnecessary mass.
I agree, however, that if you're doing anything more extreme then it always pays to be cautious. One that started out as a 2.4 TDCi 110 XS
Post #14432 20th Aug 2009 9:27am
Glynparry25
Weight bolted to the axes will not be included in the carrying weight as it is weight on the axles only- not the suspension (my axle guard is the heavyist item of protecion on my car (almost as much as all the other items together).
Glyn
Post #14436 20th Aug 2009 10:50am
mse
Sprung and Unsprung weight has different effects - but any weight on the car has a massive difference.
Just get in one with nothing in! Mike
Post #14463 20th Aug 2009 7:46pm
sasha2001
Diff guards Used the clamp on ones for years, just did a tiny spot weld so it did not move and survived a few hits on the TD5 and good on the Puma also
Post #14466 20th Aug 2009 8:08pm
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
An old thread but seems the right place to post.
Just bought this, from N4.
8mm Aluminium, I bought this one as it covers the brake drum, the only downside is that it reduces the ground clearance a little, we'll see how it performs.
Post #229257 21st Apr 2013 8:35am
