![]() | Home > Maintenance & Modifications > Warn 9.5 xp from a Disco 3 kit install question |
It should bea simple job. Have you contacted 10forcash on the D3 site
dshickle Member Since: 09 Oct 2007 Location: Epsom Posts: 36 ![]() ![]() |
10forCash - fantastic help.
![]() Once I have it fully figured out - i'll post something here in case it is of benefit to anyone else. David Disovery 3 TDV6 SE Defender 90 XS 2.4 Defender 110 S D250 (MY22) |
DAM_DEF Member Since: 20 May 2016 Location: U.K. Posts: 3 ![]() |
Sorry to come back on a very old post did you conclude installing the Warn 9.5 xp I am facing the same dilemma no documentation to follow.
John Fair Member Since: 10 May 2016 Location: Norfolk Posts: 150 ![]() ![]() ![]() |
The standard control plug completes a circuit to a remote battery isolator on the D3. ie there is no main battery live at the solenoid if the controller is unplugged. Personally I would replace the solenoid box with an Albright as its a smaller neater package and simply put a good old fashioned manual battery isolator in the main cable. Hope this helps.
Thanks for the reply, agree the Albright would be much neater and simpler will upgrade at some point so far making progress only the blue controller cable is a mystery now, rest up and running
Unfortunately no I cannot recall and I no longer have the vehicle to go and look. They are a relatively simple system so what do you have wired to where? It may come back to me. There is a winch in, winch out, and a basic ring circuit that completes to turn on the remote battery isolator ie the hand held completes the circuit constantly when you plug in.
You should have a remote isolator a bit like this or a variant of it.
I absolutely have that solenoid and I have taken the white constant 12v live via this to the controller and on my set up this is all working fine I just have an obsolete blue cable, warn list as thermal cut out..... I can live with it being detached more curiosity of correct usage. Thanks so much for the response.
I don't recall ever having a thermal cut out wire. If it all works I should just ignore it. It does work??? i do recall the origional wiring had to many wires and clutter. Sorry I can't recall more. It may well come back to me. Again I would just say change out to an Albright. It really is a better package and your in there now anyway.
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
I've fitted a 9.5 xp from a D4 to my 110. Had to get the remote socket removed and connected to the solonoid box. Made a metal bridge over the drum to hold the control box. I had to extend the wiring from winch to battery.
Can take pics if required 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
