Home > Puma (Tdci) > MPG
Page 2 of 3 <123>
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Caterham wrote:
damn ! I knew there must be a bit more to come.....
Embarassed
found out my front tyres were only at 20psi ! and rear about 30psi.....
no idea how thats happened. I'm sure its not been back to the dealers since I checked them last (so either I was dumb enough to put so little in or they're all loosing an equal(ish) amount of air Confused
Should save you a bit of fuel pumping them up to the right pressure, 32 front 36 rear for me. Smile 130 crew cab
98 V8 Disco
Post #143294 4th May 2012 7:38am
Caterham
I hope so.
If I remeber I've got the front at 30 but might take that to 32 and I'm sure I put the rear at 40 which seems ok and not too crashy. Thumbs Up
Post #143295 4th May 2012 7:43am
50H
90 T/C.
302 miles 49.11 litres / 4.546 = 10.8 Imperial gallons = 27.96 MPG.
Half the mileage was local pottering about on 205x80x16 tyres, the other half Motorway on 235x85x16.
RPM's no higher than 2000 at any time.
H.
Post #143745 7th May 2012 10:20am
If using two different tyre sizes like that, have you taken into account that the odometer will be either under- or over-reading when using one of them? Darren
Post #143751 7th May 2012 10:52am
50H
No.
What's the calc?
Post #143786 7th May 2012 2:01pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Odometer calculator
IF your odometer was correct when on the 205's, with the 235's on your speed will be 65.8mph when your odometer reads 60mph.
Nice representation of the tyre size difference shown here...
http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
Post #143833 7th May 2012 6:13pm
TR51 is essentially correct, except that the odometer is the part that records the distance you've travelled rather than the speed you're travelling at.
If your 90 was originally delivered with the 205 tyres, then the speedo and odo would be calibrated for that size. The 235 tyres are around 10% bigger, so for every 100 miles recorded as travelled, you'd actually have covered 110 miles. This would have the effect of improving your MPG, but you'd need to know exactly how many miles were recorded on each size of tyre to work it out properly.
The opposite is also true. If your 90 was originally set up for 235's and you swapped them for 205's, then your odometer would over read, i.e. for every 100 miles recorded, you've only travelled approximately 90, which would make your real MPG figure worse than it seems.
None of this takes into account the inherent inaccuracies in speedos and odo's, but as we're all dealing with essentially the same inaccuracies, then the figures can be usefully compared if even they aren't strictly accurate. Everything is relative, as the saying goes. Darren
Post #143908 8th May 2012 8:26am
TR51
Woops Embarassed
Thanks for the clarification Thumbs Up and better explanation!
Post #143917 8th May 2012 10:16am
xatzhs
Re: Odometer calculator
Great website! Really good to get an idea of what I want on my next tyres!
Just a quick Off Topic question... How wide can you go on tyres before you a) need wider rims, and b) need to adjust the steering stops?
Currently on 235/85/16, thinking of going up to something like 265/75/16 which gives roughly the same figures for distance travelled etc. Presumably the wider the tyre, the better the grip on and off road?
Post #143932 8th May 2012 12:32pm
265's will fit on the standard Boost alloys but are a bit big for standard steel wheels. You may need to adjust the lock stops, but it seems to depend on how it left the factory as some do and some don't.
As for better grip on and off road, that really depends on the type of tyre and the prevailing terrain. Some tyres work better in the narrower widths and visa versa. In practice though, I doubt you'd be able to tell much difference between 235's and 265's in most of the typical Land Rover tyre types. Darren
Post #143935 8th May 2012 12:42pm
TR51
When I changed from 235 General TR to 265 BFG AT's the deeper tread pattern put the spedo 2mph out (high), fit perfectly on Boost Alloys with no alteration to steering stops.
I found, from my experience, the wider tires reduced the rocking while cornering... JMHO Thumbs Up
Post #143941 8th May 2012 1:20pm
xatzhs
That's exactly the change I'm thinking of making. What are the other numbers for your tyres? 265/?
Post #143949 8th May 2012 2:09pm
TR51
Old tires : 235/85/16 (General TR)
New (er) : 265/75/16 (BFG AT)
Hope this helps... I can take a picture of the all terrains on it tonight if you want a look, and have an old photo with the generals on kicking around somewhere.
Post #143952 8th May 2012 2:42pm
xatzhs
That's exactly the change that I'm looking to go for, could you PM me them so I stop ruining someone's thread haha!! Sorry, back to MPG... Whistle
Post #143975 8th May 2012 6:20pm
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Over the last 2518 miles I have been recording the fuel consumption in a nice Android App and have consumed 479l of diesel
I averaged just over 24.5 mpg in a TD5 110 XS SW on the standard LR fit 235's, thats with a full unladen roofrack as in the photo at the top of the web page.
I commute 11 miles each way most of which I tend to pootle along at 60mph though thats climbing the Chilterns every morning.
Post #144086 9th May 2012 11:40am
Page 2 of 3 <123>
