Home > My Defender > My Defender 90 XS " The Dragon " |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3616 |
great mods I was considering the parking sensors in the jacking hole thing do the work OK ? Ive not done much to mine yet the but i have fitted a glove box conversion from Germany that cost £80 which is a bit steep but having fitted it im chuffed to bits and the Mrs keeps here mitts , sweets sunglasses etc in it. I also fancy one of those radios with the screen that comes out for DVDS and has a built in sat nav and will also allow a camera to plug in just got to find one for a sensible price thad does all main functions Radio, CD, DVD, SAT NAV and Camera
15th Apr 2011 10:18am |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Hi Zagato,
Bumperettes were from Paddocks: http://tinyurl.com/3ow7g7p However they need a 10mm spacer to clear the Bolt heads that are part of the rear seat mechanism/seat belt, unless Paddocks have changed the design recently. I did email them with the problem and pictures etc:. However my friendly Indy made up some spacers for me that did the job. Now guarenteed to make mincemeat of anyone who doesn't stop in time. |
17th Apr 2011 12:29pm |
Hi Defender OFTheEarth,
Whatever gave you that idea? Was it the Dragon? |
17th Apr 2011 12:31pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I'm about to get this one, there is another car only version. http://shop.snooperdirect.com/product1270186.html |
17th Apr 2011 12:42pm |
Hi Kez,
Nice Defender { Black is Best }. Fitted the reversing kit myself. The kit can work with 2,3 or 4 sensors. I used 2 and inserted them in the Hi-Lift jacking point in the rear crossmember using Ducktape to bulk them up and jammed in position. No holes to drill there. Wires went along back and into the cab via a hole in the rear OS by seat mechanism. Tap into reversing light feed at that point, also brought along rear from reversing light feed, and the control box and buzzer stuck on bare body panel just behind drivers seat. It also has a small LED sensor that I fitted to dash. Wires/plugs etc are of more than sufficient length and are robust. Will try and find the box in the garage and post with make etc: |
17th Apr 2011 12:46pm |
Landie Boy Member Since: 15 Jan 2011 Location: Essex Posts: 431 |
Looking good
Jack |
17th Apr 2011 1:30pm |
Kez Member Since: 11 Apr 2011 Location: UK Posts: 271 |
Cheers WelshGas, nice jon indeed. If I was to attempt it, it woudl burst into flames on the motorway (that actually happened to a friends car that I fitted a radio too back in the 80's - she was not impressed
17th Apr 2011 1:44pm |
Hi Kez,
this is the one I have, made by Brigade. http://www.brigade-electronics.com/product...r-system-2 |
17th Apr 2011 2:37pm |
Thanks WelshGas, looks a tidy piece of kit too
17th Apr 2011 4:45pm |
Hi Lorryman 100,
Nice piece of kit but I would be too worried about security. |
17th Apr 2011 5:43pm |
The sensors with the kit I used, see previous posts, are rubber and designed to be inserted into a hole drilled in a plastic bumper. I just made them bigger by winding duck tape around them, then covering them in waxoyl and pushing into the hi-lift jacking points. Work very well.
If you look very carefully at the photo of the Dragon, 1st post, and if you can zoom in on a photo of the rear view you can just make them out as they are black in colour. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
8th May 2012 5:01pm |
joelyates18 Member Since: 22 Dec 2012 Location: Neath Posts: 39 |
Nice truck I'm also in South Wales! 2000 TD5 90 'Lemmy'
Happy Roving! |
31st Jan 2013 8:08pm |
Hi joelyates18.
I belong to the South Wales Land Rover Club. Members from all over S Wales. They meet on the 2nd Thursday evening of each month at 7pm at a pub just outside Cardiff. May be a bit far for you but they have members from Merthyr, Aberdare etc. If interested check them out here. http://www.swlrc.co.uk LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
31st Jan 2013 10:09pm |
Cool will do 2000 TD5 90 'Lemmy' Happy Roving! |
31st Jan 2013 10:36pm |
