Home > Maintenance & Modifications > Laptop Mounting
The Musketeer
United Kingdom 1988 Defender 90 Other HT Cairns Blue
Laptop Mounting
Has anyone mounted a laptop on the passenger side of the dash?
Is it a custom job or has someone invented a "proper" one yet?
Thinking about doing it, obviously need a converter too.
atb
Sam Good things come to the wild and free
Post #143684 6th May 2012 10:23pm
leeds
RAM mounts do various device holders.
It all depends on size and weight of your lap top
RAM 243 holds a lot of lap tops. Minimum ball size would be C or 1.5"
If your lap top is heavy go up to D or 2.25" ball
Then you will need a base and arm to go with it.
Brendan
PS If you are going to Driffield at the weekend, come along and see our vehicles as we have various Ram mounts in them
Post #143728 7th May 2012 8:53am
hi Sam
Like Brendan says RAM Mount are the biz.
In a nut shell you'll need a "tray" to hold the tablet/computer/ipad, then an arm and finally the fitting to connect to your truck, really depends on your dashboard or where you are planning on mounting it
I had 2 in my 90 but have taken one out. I have one mounted on my cubby (loc-box) and one on the passenger grab handle (going to be repositioned and used to mount a camera)
I bought 3 different mountings and physically tried each one then returned the parts i did not use.
There's a few threads on the forum, search "ram mount"
Post #143737 7th May 2012 9:46am
The Musketeer
Brendan
Hi Brendan,
Looking at the range of RAM mounts is frying my brain! What would you recommend for 15" Laptop? I like the sound of mounting it on the left hand grab handle, so it would be accessible from the passenger seat and viewable from the driver's, but (I think) still quite discrete when not in use/you take the massive platform off! Idea being that I could use a converter from the cigarette lighter to run the charger and then work from there. An idea of cost would be ace too if you can, I can't find anything on your site. Good things come to the wild and free
Post #143787 7th May 2012 2:20pm
leeds
A couple of things for you to consider and play around with.
Lap top what level do you want it below say top of grap handle?
How heavy is your laptop and it's thickness?
Have you got a metal cubby box? That might provide a solid fixing and might work out cheaper. What height do you want it above mounting point on cubby box.
What sort of driving will you be doing with laptop open? Just on road use, or extreme offload.
Also need to bear in mind that laptop does not get in way of gear stick.
Brendan
Post #143788 7th May 2012 2:33pm
The Musketeer
I would like it so the screen is above the dash if that makes sense, so the keyboard below the dashboard.
Thickness of base/keyboardy bit; 2.5cm
Total thickness (shut); 4cm
Weight; 5lb 11'
It's actually 14.7cm x 10cm
No - standard exmoor type thing.
Roads and stone tracks, nothing too serious. Good things come to the wild and free
Post #143790 7th May 2012 2:50pm
leeds
Exactly what laptop have you got? Reason why I ask is the dimensions that you have given does not seem right to me.
14.7 x 10cm seems rather small. 14.7 x 10" yes
So am going to assume inches, 4 cm thick also seems large but there again I am use to Apple Macs.
With Ram mounts you basically need a device holder, arm and a base.
The two possible laptop holders are
1) TOUGH TRAY UNIVERSAL LAPTOP HOLDER C/W ANGLED CLAMPS RAM 234-3 Look HERE
Since you are using the laptop with vehicle in motion also a locking kit RAM-234-LK2. Look here
The other choice of laptop holder is
2) TOUGH TRAY UNIVERSAL LAPTOP HOLDER C/W FLAT CLAMPS RAM 234-3FL look HERE
Again a locking kit RAM-234-SNM look HERE
The device holder needs a mount base with 1.5" ball RAM 202 ROUND BASE WITH AMPS HOLE PATTERN AND 1.5" BALL
Look HERE
Then an arm such as DOUBLE 1.5" BALL SHORT SOCKET ARM RAM 201 B. Look HERE
To attach it to the grab handle how about BASE WITH BALL AND STRAPS RAM 108 B Look HERE
Hope that helps
Brendan
Post #143839 7th May 2012 6:37pm
The Musketeer
Look HERE
Hope that helps
Brendan
Your right about the measurements Embarassed
It's all food for thought though. The other option is getting something made. My current idea is a "hook over" type thing that clamps to dash top and clips into the slot between the dash and the windscreen. Probably then some sort of tray with sides that the laptop sits in and a over keyboard strap affair.
I'll think about it some more and get back to you mate, really helpful - thanks very much! Good things come to the wild and free
Post #143854 7th May 2012 7:54pm
AndrewS
Re: Laptop Mounting
yep
 130's have feeling's as well you know Smile
Post #143875 7th May 2012 9:13pm
