![]() | Home > Td5 > 1999 td5 engine |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 ![]() ![]() ![]() |
I think you can do either , I have a td5 1999 and it has a later nnn type ecu that is remapped.
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Hmm I thought they were different to later ecus who map have you pt I had a twisted box in my old defender 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
I wish I knew, it was done before I bought the car and I never asked the question. Goes really well tho considering it's done 200k miles. Still have old ecu msb type makes massive difference when I put it on just to try. It did not stay on for long lol.
I personally like the look of the attic boxes where you can switch between 3 different maps. ![]() |
Yer I have the bas interface for my puma but was unsure about it working on early td5s
Cheers steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6215 ![]() ![]() ![]() |
Early Td5's, like yours at 1999, should have had the non-flashable ECU's (and usually 10P engines), although like you say, yours has the ,ater NNN ECU which can be swapped in place of the non flash type (i think that the early ECU is no longer available anyway thesedays.)
Again, i think, that the 15P engine and flashable ECU came in about 2002 when the dash was upgraded slightly with the center switch panel. |
so what can u actually get from a td5 reliably 2015 2.2 tdci hardtop xs
Mine's running 195BHP, from IRB, with a VGT turbo.
Pulls exceptionally well, doesn't smoke too much (passes the MoT anyway), and the temp guage never seems to move up when gunning it up steep hills. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
as Jamie said, 99 Td5 is non flashable if std ECU.
stick to less than 200bhp for reliability. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
I shall probly go to Bas or alive !?!? 2015 2.2 tdci hardtop xs
Also on this truck the mid section has been replaced but I can't see an cat on the truck did they come with one or has it already bean removed
Stvrb 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
I think yours is too early for a cat.
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Pop over with it one day Steve and ill add a chip to the ecu if its a old MSB type. As said by jst,stick to less than 200bhp for reliability.
Pete |
No probs pete I'll send it down just put the highest performing map you do onto it
Cheers mate Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
get another turbo manifold and get it skimmed steve. that'll be the first thing to play up. Guess you have removed the EGR, the cat..if its got one and the mid box.
Is it manual? |
