Home > My Defender > New to forums - HELLO!!!
Page 2 of 2 <12
stup_93
the wheels went from 235 x 85 x 16 BFGoodrich to 285 x 75 x 16 Cooper Discovery STT.
No wheels spacers fitted as people said it would not rub...... but it does Confused . I adjusted both of the steering lock bolts but it still catches in full lock to the left (weirdly right lock ok). it just catches the radius arm. So I will have to get some spacers after all but its a shame as the tyres sit nicely nicely as they are - spacers may make them stand out too much. It made the revs at 60 much better.
Stu
Post #143228 3rd May 2012 7:32pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
You'd be better getting some off-set rims to match the wider tyres, rather than putting in spacers. Better for the vehicle, safer. If you want to keep the alloys, better off with narrower tyres!
Post #143243 3rd May 2012 8:18pm
stup_93
Safer??? In what way?
Post #143246 3rd May 2012 8:35pm
Pam W
There is much debate about the possible effects of wheel spacers on other components - extra stresses and strains etc causing them to fail prematurely or unexpectedly. Hence a possible safety issue. Some insurance companies are unwilling to insure vehicles with them fitted. The fact they are not allowed in MSA off road motorsports also suggests there are possible issues or concerns. Also some spacers are poorly made and obviously if they fail then it may cause safety issues.
Whereas with modest off-set good quality rims, suitable for the application (ie tyre size and use) there are no such concerns.
If you aren't sure then have a good poke around forums etc.
Post #143253 3rd May 2012 8:55pm
stup_93
I had heard this before but was told it was a myth caused by cheap spacers. I will have a look, I don't want them on if they are not right.
Post #143255 3rd May 2012 8:58pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Not wanting to restart the whole debate, google is your friend. just clarify a bit for those who don't know the background as it is mostly forgotten in the discussions.
oh, and of course Welcome !
Offset rims or spacers and physics (at least mine) give me the same forces and results. so yes they will increase the forces on the hubs, (for the same tire specs) It doesnt make a difference for the forces if you use a wooden or metal stick to apply them.
the earlier spacers were bolt-through and were indeed dangerous if bolt/stud spec was not up to it. You had to use longer studs or bolts which went through the wheel and spacer, so sandwich the spacer between wheel and hub (in speed related motorsport these are still used if allowed, but these are not 30mm or more but 3-10mm thick) The good type spacers used on offroad vehicles use the original studs or bolts to fix the spacer to the hub and have own studs or boltholes to fix the wheel to the spacer.
There is a lot of junk on the bay so be suspicious and be informed. I saw spacers for sale using cut off bolts as studs... Big Cry accidents waiting to happen. The good ones use OEM or equal studs. that as a question to a seller is a good indication for the overall quality i experienced. (paid over 300 euro for mine, and they have TUV approval)
just fyi
Smile
Post #143267 3rd May 2012 10:13pm
Page 2 of 2 <12
