![]() | Home > Td5 > td5 mpg |
Mine's generally around 25mpg, mud tyres, full length heavy roofrack, usually too much junk in the back and I do sometimes(too often
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Close to 40 mpg on 1.222 gears on a steady run in gear 5. Egr removed, mid box removed and stock tune.
Usually will manage 35 mpg on town driving. Yes, the 1.222 does help. Ambient temp ranges from 28 to 34 deg C Defender 90. The defender has migrated, leaving the owner behind. |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
ciderdrinker Member Since: 04 Apr 2010 Location: cardigan Posts: 21 ![]() ![]() ![]() |
may be worth fitting a disco tranfer box then! cheaper option than fitting an overdrive!
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 ![]() ![]() ![]() |
In mine I used to get 26.5-28.5mpg, which I was reasonably happy with, bearing in mind it is an auto and generally auto mpg isn't as good as a manual.
Since fitting the roll cage though I am getting a pretty steady 25 mpg. Not so happy ![]() |
40mpg
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Did LR design all their engines to have very similar MPG. My 300 did similar MPG to those quoted above and my Puma is similar as well. Best i have had in the 300 was nearly 30 and same with the Puma. Worst mid 20's. BM52
My 5 bearing 2286cc in a SIII 88" PU only ever managed 22 mpg.
If I pushed it it went down to 18.5 mpg. Max with overdrive 65 mph. They have inproved a bit since then ![]() |
Sounds amazing, but it's 14km to 1 litre. That's at 1970rpm. Which gives me about 90km/h. Gps tracked
40L gets me 580km. Yes, we are talking about cruising in 5th. Just go gentle on the right foot! So let's take things a ill less positive with 530km So it's about 13km/l which is still pretty good. Vehicle is on 235/85/16 general grabber. 10yrs, my2002 Serviced at 10k km interval full syn oil. Conversion table http://www.mpgtokpl.com/ The defender has migrated, leaving the owner behind. |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Got 36 a couple of times. Average was 28 lowest 22 pulling a heavy cherry picker. All standard apart from MTR tyres and a snorkel.
Ah, so that's just at that sort of steady speed? Most folks quote MPG as an average from one tankful to the next, which takes into account the wide variations between accelerating and coasting, hills, etc. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 ![]() ![]() ![]() |
Been on holiday this past week and did just over 600 miles on the west coast of Scotland and averaged 31mpg.....
![]() Def 90td5 CSW xs 2006 |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
Used to get 31mpg out my old 90, and that was on country lanes, but straight-throught exhaust, silly filter and viscous fan taken off.
New 110 (still a Td5) gets closer to 28. Snorkel doesn't help though. Soon to get a freer-flowing exhaust and a remap to help thing out ![]() |
just worked out on my last tank i managed 29.1! quite pleasantly surprised! 90 td5 csw
90 200tdi series 3 petrol series 2 diesel series 2a v8 Freelander 2 |
