Home > Puma (Tdci) > If you're thinking about a BAS remap... do it!
Page 2 of 2 <12
bell-auto-services
If the revs are low and the throttle is hard down this can be expected a little as the engine is trying to pull hard max torque while the car is under a lot of load from the low revs you have on on a high gear. Its due to the driver demand torque which is instructed from your pedal position.
Pete
Post #141973 26th Apr 2012 8:07pm
Mynstral
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hi Pete.
Only seems to happen in 6th doing 50mph+.
Regards. Smoke me a kipper I'll be back for breakfast.
Post #141979 26th Apr 2012 8:35pm
bell-auto-services
But at what rpm and throttle position ?
Post #141982 26th Apr 2012 8:43pm
Mynstral
Hi Pete.
Done more miles today, using different driving tecnique. Accelerate hard in 5th and use 6 as overdrive.
Would a larger intercooler and/or hybrid turbo help with the issues with hard acceleration in 6th?
Regards Myn. Smoke me a kipper I'll be back for breakfast.
Post #142497 29th Apr 2012 9:45pm
bell-auto-services
Hi
Its hard to give you an answer as I still dont know at what rpm and throttle postion you have a judder.
It does seem from your last post that you may have been putting it into 6th a little to early in the rpm range and really loading the transmition up and this would could a drivetrain judder simply from the stresses you are putting on the car.
Adding an intercooler and hybrid turbo will give more power than you have now for sure, but wont cure drivetrain loading issues as this is gearing.
Pete
Post #142510 29th Apr 2012 10:06pm
Mynstral
Hi Pete,
Going away with it over the next weekend, I'll report back after.
Post #142515 29th Apr 2012 10:32pm
jayaway44
2012 Defender 110 Puma 2.2 USW Stornoway Grey
Hi
The 2.2 is done we are at the moment working on a way to feasible and commercially pratical to install it onto public cars. I should be able to provide more info in the not to distant future.
PS, thank you all in the thread for your great comments on our tuning and customer support.
Pete
Pete how are you getting on with the 2.2, are you ready to market it yet?
Thanks 2.2 2012 110 utility Orkney Grey
Also
Range Rover Evoque - Surprising but I like it.
Previous
Freelander 2 SD4 HSE - Black
90 TD5
Discovery 3
Early Discovery.
Post #147020 25th May 2012 12:34pm
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
A few people have mentioned the issue in sixth gear, I had it at around 2,500 rpm until 2,800.
However my issue was definitely related to a decat exhaust, Pete supplied a different map and now it is brilliant.
I see that Pete now advises caution with decat exhausts and back pressure, however the combination I am running now, pulls like a train.
Great customer service and you get the impression, if you have a specific problem on your car, that Pete really wants to find a solution.
Post #147233 27th May 2012 8:51am
jst
Mynstral wrote:
Hi All.
Just installed the remap from BAS. Wow!! Only concern, judder/shimmy in 6th when giving it large. Is this normal before I call Pete?
Regards Myn.
judder from vibration of steering/chassis or the engine? or hesitation in the engine? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #147472 29th May 2012 7:19am
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
If the shudder is only happening in sixth gear when there is the most residence in the driveline my guess is the clutch can't handle the extra torque.
Post #147561 29th May 2012 5:55pm
marklockett2103
i get the shudder in 5th and 6th at low revs, worse when towing, adjusted driving style stops it. i figured it was the propshaft complaining about the extra torque.
Post #148898 6th Jun 2012 3:51pm
Page 2 of 2 <12
