Home > Technical > Defender standard suspension
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
In a bid to get an answer to the question - what is wrong with factory fit Defender suspension I would lile ask members.
Post #141817 26th Apr 2012 12:24am
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Nothing. Rhubarb and custard let fly with their secret weapon.
Post #141820 26th Apr 2012 5:08am
Very much depends on how you use your truck.
My 90 is an "off road scratchy", standard AT tyres, standard height springs, no a/r bars and I've not got stuck in some pretty nasty conditions. A/R bars would improve road manners but it's no sports car.
I've not tried lifting (I have enough of a challenge getting the standard height truck in the garage) not upgrading the struts so I don't know if it's "improved".
Post #141825 26th Apr 2012 7:13am
landy andy
Depends on what you are doing with it?
Standard suspension is a compromise, as most standard items are.
Andy
Post #141827 26th Apr 2012 7:32am
MartinK
Mine (110 USW) is great when loaded.
But when unladen, the rear end is a bit too bouncy (on road) for me - I'm investigating swapping the rear springs for something less harsh. A job for this weekend.
I hardly ever load the vehicle up to max...if I have a big or heavy load I prefer to use the trailer because it's easier to load and unload than using the rear door. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #141835 26th Apr 2012 8:02am
Zagato
Re: Defender standard suspension
Why the question? Confused Need more background info otherwise as Lambert says nothing Thumbs Up
Post #141836 26th Apr 2012 8:08am
rossy
if you find the ride a bit harsh you can always experiment with tyre pressures.
The recommended rear pressures for my 110 are 48psi but I have them at 43 as I want to keep my fillings !
Post #141873 26th Apr 2012 12:46pm
Peter
Ok vague question I know, just wanted to see if others thought the standard springs and oil filled shocks are as said a compromise on cost. Just fishing really to see what others think. Bearing in mind it would not cost much to Galv the chassis for instance and I wonder if they test the vehciles with the same suspension they are sold with.
Post #141989 26th Apr 2012 9:18pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Standard is fine and cheap to replace if broken.
Changing suspension is a minefield and many people having played/ spent a lot of money/ have reverted back to standard, particularly if they have raised the height.
Unless you feel you have greater engineering expertise than Land Rover - leave alone!!
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #142043 27th Apr 2012 11:33am
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Fair point well made but owning a Defender you might sometimes think my Dad's cat has more engineering expertise than Land Rover lol
C 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #142045 27th Apr 2012 11:36am
LRSoffroad
all depends what you want from it and how you are using it, everything is a compromise
as std does all things will but master of non Thumbs Up
Post #142170 27th Apr 2012 8:32pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Ive looked long and hard at various options. I normally run quite lighht so I use standard road springs and Koni shocks.
Works for me. As said above, there are a lot of individual views and requirements out there. BM52
Post #142172 27th Apr 2012 8:39pm
bm52
Post #142173 27th Apr 2012 8:39pm
JSG
Nothing wrong with the standard set up at all. Landrover spent Łks developing the best all round set up.
It won't have the bright colour or fancy logo of some of the aftermarket kit but does the job well. You only need to fit something else if you want to 'tune' the set up for a particular application. John
2011 Tdci 110 CSW XS
Post #142760 1st May 2012 5:17pm
