Home > Maintenance & Modifications > Genuine LR Parts v Pattern Parts
roadracingtog
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
I noticed a few drips of oil beneath my 2009 110 yesterday. I discovered that engine oil was leaking from the oil filter housing. The leak presented itself recently, no leak evident before yesterday. I'd intended to do a 6,000 mile oil change anyway so decided to bring it forward having done 5,000 miles since November. The oil appeared to be leaking from the housing where it meets the underside of the engine. It unscrewed without very much effort either. No problems as such but I did notice that the sealing ring on the old oil filter, non-LR part, was a slimmer diameter than the new one that I was fitting, genuine LR filter. The new filter with the larger diameter sealing ring felt a much tighter fit as I screwed it home. Has anyone else experienced this? It's convinced me of the value of fitting genuine parts. http://www.roadracingsupporters.com
Post #141735 25th Apr 2012 8:55pm
jst
for the oil filter on puma i used Gen as price wise there is hardly anything in it.
everything else i use Bearmach supplied. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #141738 25th Apr 2012 9:03pm
RobKeay
I have so many stories about fitting pattern parts. I never learn. Example last week I fitted Landrover LED stop lights, they fitted shraight away no more than five minutes and they work. Brought clear britpart to replace fog and guess what the screws don't really line up. So need to buy a genuine plinth now.
But shop about to get best price. Gen fuel filter for td5 from craddocks £45. Whole gen service kit from duckworth £58 plus vat.
Post #141742 25th Apr 2012 9:07pm
noworries4x4
Buy cheap buy twice !!!! Bow down Bow down If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #141781 25th Apr 2012 9:54pm
noworries4x4
Or even its cheap for a reason ! or if you are clever track down OEM parts ie the ones that are supplied to Land Rover but even then sometime they are 2nd grade quality. If everything is under control you are not going fast enough.
No Worries 4X4
Post #141785 25th Apr 2012 9:56pm
spudfan
Ireland
First oil change on my 2008 Puma the independent used a non genuine filter. Like yours it leaked as yours did. Went back got him to change it. He used another -same brand- non genuine filter. Same problem. Said he uses these all of the time with no problems. Got it replaced with a genuine Land Rover filter and had no problems. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #141807 25th Apr 2012 10:32pm
roadracingtog
Thumbs Up http://www.roadracingsupporters.com
Post #141810 25th Apr 2012 10:46pm
roadracingtog
Oops, spoke too soon. After 300 mile trip, leak has reappeared. Any ideas? http://www.roadracingsupporters.com
Post #143101 2nd May 2012 10:39pm
Mo Murphy
Beware the blue box !
50 Shades of Pennine Grey
Post #143338 4th May 2012 12:14pm
spudfan
Ireland
Try a new filter. Before you fit it, give the mating surface and the threads a clean with some diesel on a cloth.It should not take long to dry. Bound to be a simple reason for it.Don't forget to use the correct torque. 1982 88" 2.25 diesel
Post #143388 4th May 2012 4:59pm
roadracingtog
Will do next time around, all OK at the moment though after nipping up the filter housing. http://www.roadracingsupporters.com
Post #143505 5th May 2012 4:04pm
