![]() | Home > Puma (Tdci) > Fuel restriction |
| sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147
Hi, does your fuel gauge work properly or are you getting this when you are low on fuel? The ecu reduces fuel to the rail to reduce power when you are/or it thinks you are low on fuel.
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
hi fuel hauge works fine it comes up with 4 fault codes identifying that each injector is on restricted fuel
but what you say could be right as i remeber that the freelanders go into limp mode when they get low on fuel ? i am going to change the fuel filter anyway but it just concerns me a little steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86
I also get the fault codes, but only when the vehicle is running (untested fault codes, I think). I tested another Puma the other day and it got them as well. At my last service I asked the dealer to check the injectors and they gave them a clean bill of health. My advice - don't worry.
Yer that's right hmm taken my mind off it a bit now cheers
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
