Home > Puma (Tdci) > Exhaust question |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10367 |
I don't think a straight thru on a Puma sounds good....nothing like a TD5
21st Apr 2012 10:47am |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
All I have is a resonator in mine and it's sounds quite throaty although you can hear the turbo waste gate through it ?
All depends what you want ? Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
22nd Apr 2012 7:02am |
K9F has a real nice S/S exhaust - it looks expensive but it works, his truck really shifts!
22nd Apr 2012 7:33am |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 |
Well I have a full stainless system on mine now with a de cat and 1 big silencer in the centre I'm thinking of removing it its a JE tuned stage 2 so hopfuly should get a bit more of a note just don't want it to sound s##t |
22nd Apr 2012 1:15pm |
Griffin....
It gets rid of the catalytic convertor and the rear box, the centre box instead of having offset inlet/outlet pipes it is straight through. Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Apr 2012 7:52pm |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 609 |
One of our uk distributors sell a version of our sports exhaust system with only the rear resonator box, as they think its sounds the best!
The problem with removing the center silencer is it does increase the amount of booming within the cabin, but gives an impressive exhaust note. Our performance systems normally come with a straight through middle silencer, and rear resonator, to reduce any unwanted cabin noise, but a straight through mid pipe can be an option. Some say it is too quiet with the silencer, but thats because the noise is coming out the tail pipe and being left behind you, rather than it booming into the cab! Regards, Gary. |
23rd Apr 2012 7:49am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Agree |
23rd Apr 2012 8:00am |
I have one of these on my td5, the sound is great and no booming...
http://www.alivetuning.com/Land-Rover-Sports-Exhaust-Systems.html |
23rd Apr 2012 9:50am |
defender4 Member Since: 22 Jun 2011 Location: South East London Posts: 411 |
I have a straight through TIG welded 304 stainless steel centre box from Ian at IRB Developments on my 2007 Puma.
There is some increase in cabin noise but it's a sound that I'm happy with because it's relatively subdued and isn't the tedious boom that I understand some straight through centre boxes produce. |
23rd Apr 2012 10:00am |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 |
when you say Griffin, do you mean http://www.ebay.co.uk/itm/Land-Rover-90-De...335975b931 and whats the crack with having no cat, at MOT time?? cheers, Harry. |
23rd Apr 2012 8:09pm |
Harry,
Having no catalytic convertor at MOT time is not an issue and has been extensively debated and discussed on here. That is indeed the same company on the e-bay advert. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
24th Apr 2012 10:45am |
thanks ive spoken to James at Griffin and he said they were unsure of how MOTers would be. he also said that they could put a dummy cat on the exhaust but from what you've said i wont be bothering with the cat. thanks again and does it give a throaty sound?? |
24th Apr 2012 7:10pm |
Harry,
I am surprised at James for being in the exhaust making business and not being aware of the new 2012 MOT rules regarding the failure of an MOT on 'Sparked Ignition Engines' (NOT diesel) for a missing catalytic convertor. See my post page 2.... Details here: http://www.defender2.net/forum/topic10363.html?highlight=sparked With regards to noise see comments page 3 here: http://www.defender2.net/forum/topic3204.html?highlight=griffin If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 24th Apr 2012 10:39pm. Edited 1 time in total |
24th Apr 2012 9:10pm |
24th Apr 2012 9:20pm |
