![]() | Home > Puma (Tdci) > Puma Gearbox |
| BigGeorge Member Since: 08 Aug 2009 Location: Zurich Posts: 43
well... I had
after about 10'000miles my clutch was replaced (together with rear diff). A few weeks later LR acknowledged that the gear box was finished too and replaced it. So far no specific issues other than some noise when going faster George The goons are trying to bring me down! Defender 110 SW MY10 useless piece of Defender 90 V8 50th Anniversary Series IIa 109 / 6 cyl. ex-fire truck |
| Pauly Member Since: 19 Jun 2008 Location: Dresden Posts: 11
@BigGeaorge
what was the reason/diagnosis for the faulty gearbox? Pauly All science is either physics or stamp collecting. (E. Rutherford) |
| Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 672
just had the clutch replaced and its completely transformed the car.
Before i had loads of gearbox noise, now its silent. Cheers Ian |
| Fontuin Member Since: 11 Sep 2008 Location: South Africa Posts: 29
My clutch has been replaced twice, both times due to loose pressure plate springs causing a very noisy rattle.
LR seem to be strugglng to sort this one out because my second clutch also rattles although it is a lot quiter than the first two, I'll have it checked out at my 50k(km)service again. The replacement clutch that does not rattle(rattles less) has transformed the vehicle. |
| CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558
Mine had a terrible rattle which was sorted for a while with the revised clutch and pressure plate.
Noise is back and getting worse. I think the gearbox or clutch is shot. I need to take it further because dealer insist they can't hear it. Puma 110 - gone Series III 1973 - going strong |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
Do you all tow trailers etc., if so that may be the cause,I know thats what a Defender is for but just wondered. 2.4 90 XS
I do. I towed a 2.6 metric ton load 500km this weekend again. How could this be the problem?
The early trucks had Transit clutches in and weren't up to the job,that's why I asked. 1968 1/32 scale Britains 109 Pick up. |
| Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141
2 new clutches, new gearbox, new transfer box, 2 new rear half shafts and it still drives like it's 15 years old and the gearshift is worse than ransid pants!
Bosun. |
| slocum Member Since: 16 Oct 2008 Location: Italy Posts: 19 |
Clutch replaced, gear box replaced, transfer box replaced, front shaft replaced, rear diff replaced. Now I'm waiting for a complete rear axel.
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
Clutch replaced on mine i tow the limit and more every day and after i had a new clutch
replaced iv had no problems whatsoever, before the clutch the transfer box gear stick use to rattle like faaaarrrk NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Clutch replaced at around 6,000-8,000 miles.
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
None of you have had the selector replaced i see and this is a common part.
Ive had a new clutch and they broke the selector and the 2 have changed the car (i drove it on the broken one...no big deal change wise) I also had to have a new selector plate about 6 months ago when there was a rattle but they wouldnt do the clutch - that changed things. I wonder how many just need this change? The new modified front prop also helped when the nipples dropped out of the last one. Mike |
What test can we do to eliminate the selector being at fault Series III 1973 - going strong |
| All times are GMT |
