![]() | Home > Puma (Tdci) > Key and transceiver |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
The plip (remote for alarm) is the transmitter for the transducer coil mounted in the steering column for the passive immobiliser on the 10AS module. If you dont have the plip near the ignition when running, then the passive immobiliser will stop the engine after a few minutes by not sending a mobilisation signal to the EMS. If you lose the plip or it fails then that is what the EKA code is for.
Molusk Member Since: 20 Dec 2011 Location: Loire Valley Posts: 43 ![]() ![]() ![]() |
Thanks!
Another question: I received 2 codes with my defender: - key code - immobilization code. ---> which one to use the day my plip has trouble? |
Use the immobilization code first........ if that doesn't work then try the Key code.
Thanks again.
Hope I'll never have to "dial" them... ![]() |
Mhmmm this is better ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Birdy Member Since: 07 Oct 2011 Location: CĂ´te d'Azur Posts: 886 ![]() ![]() ![]() |
But if the “plip” is an integral part of the key, what’s the procedure for EKA (Emergency Key Access) when the manual states: “Remove the remote control from the key ring and keep it well away from the starter switch”?
Peter |
