Home > Maintenance & Modifications > Ceramic exhaust - ALIVE Tuning?
gambit
Having a spot of trouble with exhaust blowing - not much at the moment, but is not going to get any better.
So looking at various options; anyone have experience of the ceramic exhaust?
Seen on other forums - power to Google Smile - some have tired this exhaust along with a J E Stud kit.
As I am not too technical, I am clearly missing something, but why would you need/want to use a stud kit?
Andrew
Post #139316 15th Apr 2012 7:24am
AndrewS
Are you refering to a TD5? 130's have feeling's as well you know Smile
Post #139320 15th Apr 2012 8:13am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
and Manifold ? Putting Dreams on Drives at JLR Solihull..
Post #139321 15th Apr 2012 8:18am
Lorryman100
I have been waiting for someone to stock these for the Puma. But it looks like I will have to get one made up specially as there has not been much interest in suppliers supplying ceramic exhaust manifolds for the Puma. Alive tuning does one for the TD5 engine though. Big Cry
Post #139329 15th Apr 2012 10:20am
g30rge
2003 Defender 90 Td5 HT Auto Zambezi Silver
Have a chat with Gary at Alive, he might be able to do you a Puma one, does the Puma suffer from Manifold problems as well?
As to stud kit as well - quite often when the manifold is warped it snaps at least 1 stud (I had 4 go on my D2)
This entails possibly having to drill out the broken stud(s)
Some people then fit the JE stud kit as well
I did my D2 just with ceramic manifold and new studs and did not have another problem
Post #139340 15th Apr 2012 11:22am
gambit
Ooopps
Yes, TD5 and yes manifold Banging Head
Post #139348 15th Apr 2012 12:22pm
gambit
On the JE Stud kit - are they just a better quality product than the standard ones?
Post #139349 15th Apr 2012 12:23pm
landy andy
No they also have spacer fitted between nut and manifold.
I brought them, but they did not turn up in time to use, so just removed manifold webbing, had it refaced flat then refitted it, but changed all studs to new and made 4 outer most to M10 or M12. Can't rember now. The important thing is NOT to fit new manifold, but machine old one.
Andy
Post #139368 15th Apr 2012 3:05pm
bell-auto-services
I agree with Andy, fitting a machined flat used manifold generally stops the warping from happening again. I have machined many manifolds and modifyed the webbing and not one has warped again.
Pete
Post #139422 15th Apr 2012 7:33pm
gambit
Thanks for the advice. Machine flatten it is then.
From a bit of reading, am I right in thinking that the spacers are used if you remove the webbing.
What does the webbing do?
Cheers Andrew
Post #139487 15th Apr 2012 10:02pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I have a ceramic manifold and je stud kit, and when I took it of to do a job it had a slight bow in it! Maybe this was because the manifold had never warped and when they warp and be skimmed they never do it again I don't know but I must admit it does stay alot cooler than the original manifold,
As for the studs they are a nice bit of kit, there longer and have spacers on them I will see if I can get a pic.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #139511 16th Apr 2012 8:47am
Tatt
South Africa 2002 Defender 110 Td5 HT Belize Green
Re: Ceramic exhaust - ALIVE Tuning?
Have a look at these guys: http://www.zircotec.com. Price seems to be reasonable.
Tom
Andrew
Post #139669 16th Apr 2012 9:27pm
Glynparry25
I see the TD5 manifold is really tight, But would it be possible (and wiser) to fit tubular manifold on the Puma? The increased flow will also help reduce temperature.
Glyn Dog Sheep
Post #139711 17th Apr 2012 6:14am
AndrewS
The kit (used to) consist of replacement studs that are 10mm as opposed to the standard 8mm and the new studs are longer. This involved drilling out the old threads and cutting new m10 threads into the head.
The new studs are a higher quality than the standard.
The also comes with 'bobbins' or a thick spacer washer for each stud located between the manifold and standard washer, this allows the manifold flange to expand and contract without breaking the studs. 130's have feeling's as well you know Smile
Post #139715 17th Apr 2012 6:39am
wslr
This is a JE stud kit with a turbo steady bar. TBH, usually on really tuned Td5's the stud kit and one of Alive Tuning's ceramic manifolds does the trick, but some people ask for the steady bar as well.
Jon Hollick is the chap at JE you need to talk to for a kit.
The studs are standard diameter so no extra engineering required. And do get the face of the manifold skimmed as mentioned.
Also, check you don't have an iffy remap causing manifold temperature issues, and also the cat and exhaust isn't part blocked.
Post #139843 17th Apr 2012 2:52pm
