Home > Puma (Tdci) > Amber warning light
rasmussen
France
Amber warning light
Another silly question from me Embarassed
I have bought this Puma 110sw 2008 that have been beaten up by the previous owner (or the customers of this Spanish car renting company I bought it from).
I have never own a car that have any computer or electronic systems. (My previous car was OneTen hardtop 1986 no turbo – pretty low-tech Smile
Today while driving the amber warning light start illuminate. The manual inform me that I shall ''avoid high speeds and seek qualified assistance urgently.''
My question is what is qualified assistance? Will any random garage do or shall I drive 50 miles for a specialised Land Rover garage Confused
Post #139170 14th Apr 2012 11:36am
I have had mine today too. Chances are you'll find it'll go off after a few trips. Probably the **** EGR Rolling Eyes
Post #139175 14th Apr 2012 12:13pm
rasmussen
France
Cheers for reply!
Is this really the general consensus that everyone just ignore that warning light and hope it will go away Shocked
Post #139187 14th Apr 2012 2:04pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Buy yourself a cheap EOBD code reader [£25 - £40 on e bay] and read the codes .. probably just EGR related info logged on there.
You can also reset the light and clear codes with the reader .... then see if it comes back on, how long etc, and what codes again .. Guns and Landrovers .... anything else is irrelevant.
Post #139209 14th Apr 2012 3:03pm
spudfan
Ireland
Your amber warning light is there to tell you something is amiss. It could be something like your EGR not working. I only had it on once and it was a sensor in the fuel system. It is probably something simple but you are better getting it checked out. If you cannot do it yourself you will have to go to a dealer with the diagnostic equipment to check it out. No doubt they will charge you handsomely for the priviledge. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #139215 14th Apr 2012 4:18pm
rasmussen
France
Went out for a second drive, Now the warning has gone Neutral
I am going to order a code reader now Thumbs Up
Thank you very much for your comments Smile
Post #139217 14th Apr 2012 4:40pm
Thought so. At some point in may come back and dissapear again too.
Post #139219 14th Apr 2012 4:47pm
K9F
Pound to a pinch it's P1103...... Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #139246 14th Apr 2012 6:58pm
Which is a code for what exactly? Thumbs Up
Post #139260 14th Apr 2012 7:46pm
Lorryman100
P1103 Mass Air Flow Sensor In Range But Higher Than Expected Thumbs Up
Post #139263 14th Apr 2012 7:48pm
MAF, I assume this could happen with a performance airfilter too?
Post #139267 14th Apr 2012 7:58pm
K9F
Kona,
Yes definately! I get it occasionally especially when the air is cold. It will reset automatically after a few driving cycles. I will always check and reset with the Scangauge though as when it is on it could theoretically mask another problem. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #139269 14th Apr 2012 8:06pm
Lorryman100
If the DTC fails to reoccur after three ignition cycles (passes three test cycles without reoccurring) the MIL lamp will go out and a tested DTC will be logged in the ECM. Thumbs Up
Post #139271 14th Apr 2012 8:10pm
K9F wrote:
Kona,
Yes, that's true. I've had intermittent warning light on but there is nothing wrong driving idling ect all perfect then dissapears I've got the standard filter so not that. Late last year whe I first had it had the AA out to check it and he said it was an EGR code so the code was just sleared and put on paper at the time. I seem to get it after starting and then booting it on the main road when cold. But there is no loss of power or anything at all.
Post #139272 14th Apr 2012 8:10pm
