![]() | Home > Maintenance & Modifications > Cargo tracking from MUD advice |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
You can mount the surface mounted items anywhere within reason. If you are looking to hold things to the floor I would probably put them on the floor close to each side.
The carpet won't be deep enough to mount the recessed version, you woukld need to cut the wheel box too. The surface mount will mount over carpet without any major drama's. 2002 Defender 110 DC |
Brocade Member Since: 03 Apr 2012 Location: London Posts: 9 ![]() ![]() ![]() |
Many thanks. Out of curiosity, how does one screw the nuts onto the bolts ? Does the floorboard easily lift up or do I have to crawl underneath ? |
Either use rivnuts which may require a special tool to fit, or crawl underneath and have a helper hold the the other end.
Enjoy! 2002 Defender 110 DC |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Use either a rivnut or alternatively get an allen key jammed against wheel arch and then crawl underneath.
Cargo tracking is good ![]() IF you know EXACTLY where you want your load rings consider these ![]() £14 for the two short pieces of track, backing plates etc and two load rings Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Aha I have just learned something new...the Rivnut !
Many thanks for all the advice |
I would also consider putting something under the floor to spread the load depending on what you are tying down ?
